Hp15r don't boot
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 343
    • India
    Hp15r don't boot
    HP 15R problem
    Hi. hp ZS050 LA-A992P
    Flashed bios also
    problem is display coms fine . goes inside bios fine .
    doesn't boot to any media hardisk or usb... just hard disk led turns on and laptop turns off .. than on again
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Hp15r don't boot
    replace YC1 and YC2 ( may be on your PCB) XTAL near on board CPU and post the result.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 343
      • India
      Ok i will update again thanks
      • faisalali
        • Mar 2016
        • 25
        • pakistan
        i need hp 15-r100ne bios bin file
        problem is that is switching but suddenly off with in 20 sec
        • smali
          • Sep 2014
          • 287
          • Pakistan
          Dear faisalali,
          i think it is not bios fault have you received 1.35 voltage ob RAM coil? check all voltage on coil?
          • faisalali
            • Mar 2016
            • 25
            • pakistan
            sir no voltage on RAM coil. ?
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 343
              • India
              smali !!
              Same condition. after changing both crystals.
              Hard disk led blinks 1-2times than shutting down than on again cycles.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                did you TURN OFF safe boot and TURN ON legacy or csm boot?
                Im Back... sort of...
                • abbas_govani
                  • Jul 2013
                  • 89
                  • India
                  hi guys am having some different problem. had this board la-a992p and la-a994p. both laptop have same problem. laptop power on for 4 to 5 second then it off. had reflashed the firmware but no success. any suggestion welcomed.
                  thanks.
                  • bilal1992
                    • May 2017
                    • 26
                    • algeria
                    try to change boot mod to legacy .
                    • abbas_govani
                      • Jul 2013
                      • 89
                      • India
                      there is no display. so cant change to legacy mode.
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        thanks.
                        I had the same issue on LA-A994P. I removed LVDS Connector from motherboard. Now the laptop working for long, Harddisk also reading. I checked that cable, there is short on ( Camera line ) 3v line found. Now i ordered for new cable and waiting for that. Try to flash following file have Main + EC.
                        • vishalcomputers
                          • Jan 2020
                          • india
                          Hell every.
                          I have one problem
                          Hp la-a992p. Motherboard
                          Allworking fine external display also working fine
                          But internel display only back light on no image.
                          I change creen new one ad cabel also.
                          Plz gaide me.
                          • ravi_1617
                            YY Solutions
                            • Jan 2012
                            • 343
                            • India
                            Hi ,I have LA-A992P
                            Laptop working /booting fine with adaptor power only.
                            When connected with battery.
                            Board Turns on ,only backlight is on, no text or image.
                            Board has Graphic chip too.
                            Found coil PLV1 burnt /open due to short PCV4 short.
                            Replaced both but ,no improvement
                            Battery is also no charging.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Try with another known good battery first.
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 343
                                • India
                                Already checked it ,just now solved,PQ101 was short.
                                • ravi_1617
                                  YY Solutions
                                  • Jan 2012
                                  • 343
                                  • India
                                  thanks.
                                  Hi
                                  same problem board starts and turns off after 4-5 seconds .
                                  no power at PLM2 1.3VOLT, PRM4 5R1 was open .
                                  now power present at PLM2 .
                                  now board starts ON&OFF .its self turns on &off power led on/off onoff...
                                  no power at PLZ2 .PLG1 nil power CPU stats heating slowly
                                  PLZ2 ref GND 5.1 Ohm/PLG1ref GND 2.7 Ohm suspect CPU not short
                                  PL002 1.02 VOLTS present
                                  Bios flashed
                                  still same,
                                  no replaced ISL95833B (PIZ1)
