Coloured lines and white screen with lines on Elephone P6000
  • olorin
    • Sep 2013
    • 82
    • Greece
    Hi!
    In a elephone P6000 while opens normally start logo, after a little at random times sees colored lines and / or a white screen with lines, and turn off.After opens after 5-10 minutes. Watch the video:
    https://www.youtube.com/watch?v=fJvHMx7Xb1k
    The moment that shows the lines is at 0:33.
    I wait suggestions / ideas what could be wrong and do them.
    Thanks!!!
  • dj_ricoh
    • 2073
    • uk
    Re: Coloured lines and white screen with lines on Elephone P6000
    try some tension test?
    LCD fail or the GPU?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Lcd IMO.
      • tibd
        • Oct 2014
        • 189
        • Sweden
        Had this problem on a Chinese tab with rk3066 cpu. The problem was in the cpu. changed it and optimized with copper shims , problem solved since then.
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • jeyoung12
          Samsung QN50Q60t lines on screen
          by jeyoung12
          Hi all
          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
          So....i don't know what end of the C ribbon to work with...
          02-26-2024, 10:38 AM
        • Ancient1
          White Screen with Lines. Advice needed
          by Ancient1
          Pilot PD43S9HE 43" FHD Smart.
          Main : HK.T.RT2842P639
          T-con : Nemu N2TP430FHDLV1D_A1
          Panel : CC430LV1D
          I attach photos of :
          0. The hardware , except the distribution board ( I'll create full view)
          1. The problem : White screen with horizontal lines ( no Vertical lines ! )
          2. Disconnection of one of two FLEX from T-con to Panel boards ( in the next post)
          3. Taping 0.5cm first tracks of the Flex i.e 4 times ( in the next post)
          Photos include descriptor.
          Haven't measured anything yet.
          I'd...
          10-13-2022, 01:24 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
