MacBook Pro A1278 820-2936-B webcam wires
    • 31046
    Re: MacBook Pro A1278 820-2936-B webcam wires
    pin1 - ground
    pin2 - USB-
    pin3 - USB+
    pin4 - SMBUS DATA
    pin5 - SMBUS CLOCK
    pin6 - +5v
    • angel-boy
      • 550
      • Romania
      I agree with you , but witch color is pin 1 ,pin 2 , pin 3 , pin 4 , pin 5 , pin 6
        • 31046
        look on the camera end, see the order of the wires and if one end is marked "1"
        • angel-boy
          • 550
          • Romania
          i need to open the display to see that, i dont want to do that.
          thats why i ask for help here,
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Opening those displays may require a heat gun very tricky.I tried to save your original image and then upload it to Google Images and do a image search to see if any one has posted the same wires for the A1278, but it keeps telling me it is not a real image. Also, it might help if one knew what year it was made. You can always look into getting and external web cam that you attach to the top of the display.
            • angel-boy
              • 550
              • Romania
              #26
              if you have a picture that can help me you can upload here or p.m.
                • 31046
                maybe there is a foto of the cam on ebay - do you know the part number?
                • angel-boy
                  • 550
                  • Romania
                  #28
                  no,
                  • angel-boy
                    • 550
                    • Romania
                    #29
                    i find this
                    http://mikesmods.com/mm-wp/?p=340
                      • 31046
                      actually, i searched and there are lots of cables starting at about 5
                      but you cant see the colours because of the sleeving
                      • angel-boy
                        • 550
                        • Romania
                        #31
                        please remove sleeving , and will see , will not do any damage, i remove a lot
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          If you have to take it apart this I think is maybe the best way to dismantle the screen. Even though it is not your model I think it would work.
                          https://www.ifixit.com/Guide/iMac+In...lacement/15861
                          • angel-boy
                            • 550
                            • Romania
                            #33
                            i have a laptop , not a imac
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              Yes I know. As I said in the previous post if you read and see the information from the link I think it will help you to take your macbook pro screen apart. They are using special tools for cutting the adhesive. Information on the web has people taking the macbook pro screens apart with a heat gun which I think could cause great problems. I think the cutter and information in the link I provided would allow you to take the screen apart without the heat gun.
                              As I said I do not know the year your computer was made or even what processor you have in it. This link is a service manual of a macbook pro15inch which show one how to take things apart, connectors, Etc.
                              https://cdn.badcaps-static.com/pdfs/...ee16bb056a.pdf
                              Here is a video https://www.ifixit.com/Device/MacBoo...dy_Model_A1278
                              • angel-boy
                                • 550
                                • Romania
                                #35
                                i get some help from a romania forum member
                                • angel-boy
                                  • 550
                                  • Romania
                                  #36
                                  I fix the web cam , now it`s working great. thanks all for help .
                                  • yashjovi
                                    • Nov 2011
                                    • 130
                                    #37
                                    i found something but dont match
                                    thanks for the picture apple a1278 820-2936-B camera connection details exactly matching
                                    • Adogabriel100
                                      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                      by Adogabriel100
                                      Hey! This is a A1278 macbook 2011.
                                      Problem: Not turning on / No green light
                                      Im using by3200s charger.
                                      Voltajes:
                                      PPBUS_G3H = 12.26v
                                      SMC_RESET_L = 3.3v
                                      PP3V42_G3H = 3.42v
                                      U7000 =
                                      Pin 1 CHGR_AGATE = 0v
                                      Pin 2 CHRG_DCIN = 19v
                                      Pin 3 CHRG_ACIN = 4.6v
                                      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                      Pin 12 PP3V42_G3H = 3.42v
                                      Pin 13 CHRG_RST_L = 3.3V
                                      Pin 14 SMC_BC_ACOK = 0.8V
                                      Pin 19 PP5V1_CHRG_VDD = 5.05V
                                      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                      04-01-2024, 01:02 PM
                                    • Rezendes
                                      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                      by Rezendes
                                      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                      05-10-2024, 02:18 PM
                                    • pcbmaniac
                                      MacBook A1278 (3115) No PPBUS_G3H Issue
                                      by pcbmaniac
                                      Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                      I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                      1. U7000 Measurements:
                                        • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                      2. Resistors:
                                        • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                      Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                      • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                      12-02-2024, 04:12 PM
                                    • sizar00740
                                      macbook pro 13 inch a1278 820-2879
                                      by sizar00740
                                      please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                                      07-30-2025, 10:21 AM
                                    • envym
                                      MacBook Pro 2018 with Activation Lock
                                      by envym
                                      Hi everyone!
                                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                      06-27-2025, 08:54 AM
