MacBook Pro A1278 820-2936-B webcam wires
  • angel-boy
    • 550
    • Romania
    - that webcam jack was broken , i dont know the order of colors please help ,
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: MacBook Pro A1278 820-2936-B webcam wires
    have to find the cable back.... got one for spare.... gimme some times. meanwhile lets see if someone could also help
    • angel-boy
      • 550
      • Romania
      i find something but have others colors. please i realy need to fix this one
      • angel-boy
        • 550
        • Romania
        any help please
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          im still not able to find back the cable
          • angel-boy
            • 550
            • Romania
            we are a lot of members of this forum , i`m sure that someone will help me
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Is this one I attached, the one you have? I think the below link is what you want.
              http://pinouts.ru/Slots/ieee1394_pinout.shtml
              • angel-boy
                • 550
                • Romania
                i did not find something that can help me . i realy need a member that have this laptop and can check wires color and position
                • tata123
                  • Nov 2013
                  • 104
                  Here hope this can Help
                  • angel-boy
                    • 550
                    • Romania
                    i have small conector, and 6 wires
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Yes and my post number 7 has six wires and they are the same colors as yours.
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        ur post is firewire .. this is webcam.
                          • 30994
                          • angel-boy
                            • 550
                            • Romania
                            i found something but dont match
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              Can you show where the cable is coming from? What is the connector number that broke? Is the camera internal or external? The connector that broke how many positions did it have? Does the camera support IEEE 1394 interface?
                              • angel-boy
                                • 550
                                • Romania
                                cable is coming from webcam , internal camera from display , have only one posibilon ,
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  So, where did the connector that broke connect too? The connector had to plug into a motherboard connector. Once you find where it plugs into you can ohm those points out to see if it is connection too, the USB or the Firewire.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Yes, this could connect up to the firewire if it is compatible. The schematics are showing the USB. The number and color of wire do not match up to USB. However, if it is internal than according to the schematic it connects up to the USB. Perhaps 2 of the wires are for the microphone? When I search for that particular computer it had only one isight web cam that connected to it and that was to the firewire.
                                    • angel-boy
                                      • 550
                                      • Romania
                                      so you telling me that 2 wires are microfon , 2 are data coonection, and 2 wireles 5v ?
                                      ok , but what is the order , witch is first , witch is second ..... i must put the jack , and will go into mainboard.
                                        • 30994
                                        arent those schematics i linked showing it?
                                        • Adogabriel100
                                          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                          by Adogabriel100
                                          Hey! This is a A1278 macbook 2011.
                                          Problem: Not turning on / No green light
                                          Im using by3200s charger.
                                          Voltajes:
                                          PPBUS_G3H = 12.26v
                                          SMC_RESET_L = 3.3v
                                          PP3V42_G3H = 3.42v
                                          U7000 =
                                          Pin 1 CHGR_AGATE = 0v
                                          Pin 2 CHRG_DCIN = 19v
                                          Pin 3 CHRG_ACIN = 4.6v
                                          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                          Pin 12 PP3V42_G3H = 3.42v
                                          Pin 13 CHRG_RST_L = 3.3V
                                          Pin 14 SMC_BC_ACOK = 0.8V
                                          Pin 19 PP5V1_CHRG_VDD = 5.05V
                                          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                          04-01-2024, 01:02 PM
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • pcbmaniac
                                          MacBook A1278 (3115) No PPBUS_G3H Issue
                                          by pcbmaniac
                                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                          1. U7000 Measurements:
                                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                          2. Resistors:
                                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                          12-02-2024, 04:12 PM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                          Apple MacBook A1278 051-7918 820-2327 Schematic
                                          M97A MLB Rev C...
                                          11-01-2024, 06:53 AM
