MacBook Pro 2.66Ghz mid2009 MB 820-2523-b to repair
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    #61
    Re: MacBook Pro 2.66Ghz mid2009 MB 820-2523-b to repair
    no problem for the little help. get good money and buy a good rework station dont go for the cheaper, but get some good quality to work once and well.
    we are here if u need some more help
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
    • obelix24
      A2941 Macbook air 15” - 5V 0a
      by obelix24
      I’m working on one macbook air 15” m2 that was water damaged.
      keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
      i’ve put macbook in shelf and order new screen so i can fully repair it.
      Now i got the screen and macbook stays at 5v 0a.
      i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
      i don’t have schematics so i don’t know where to start can someone help me?...
      03-27-2025, 01:19 PM
    • Askic
      Probe point corrosion -Macbook repair
      by Askic
      Hello guys,
      I'm learning about logic board (motherboards) repairs. I don't do repairs professionally, but I manage from time to time to repair something for my family and friends.
      What caught my attention is this visual inspection guide written by Louis Rossmann. It seems that corosion on probe points on the motherboard can "kill" Macbook. https://wiki2.rossmanngroup.com/inde...ual_inspection
      I wonder how corrosion cause this. If there is a track that has a probe point made on it and corrosion is build up on that place, does this means...
      01-31-2021, 10:46 AM
