Gateway NE56R10U (Compal P5WE0 LA-6901P) need to find short to ground.
  • mattpd
    • Oct 2012
    • 302
    Schematics here:
    AC adapter had 19v, but when you plug it into the laptop it drops to 0v, so I started hunting for a short. I was able to find PQ6 or PQ7 shorted. I removed both and now 19v is present at the laptop. Unfortunately there is still a short somewhere else down the line. The 19v can be measured at the source of PQ6, but there is no gate voltage and also no drain voltage.
    I can detect the short to ground on the pin 2 and 4 side of PR14. I can detect it on many of the inductors like PL3, PL7, PL13, PL17, PL22, PL24.
    Where should I be looking for this short?
  • dj_ricoh
    • 2073
    • uk
    Re: Gateway NE56R10U (Compal P5WE0 LA-6901P) need to find short to ground.
    you need to inject 3-4 v in the line.
    on those pads where you took of the fets solder a wire and connect it to a PSU and give it a minute and it will heat up.
    this method i use for every short finding.
    when i close and feel the heat i use IPA and the shorted component will evaporate the IPA
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      great...
      i am thinking to buy an infrared camera (spend many money)
      • dj_ricoh
        • 2073
        • uk
        I wish i had that amount of money for that thermal camera
        • mattpd
          • Oct 2012
          • 302
          Only 3 or 4 volts? As far as I can tell the short in on B+ rail which is 18v, right?
          • rookieme
            • Oct 2014
            • 397
            • Greece
            If it has low resistance a 1,5V battery cell usually does the job, if not I use a 18650 lithium 3,7V+.
            It should be a shorted capacitor....
            • dj_ricoh
              • 2073
              • uk
              It's more likely to be a and cap.
              That cap its rated 2.5v so you need more then that to make it great up faster.
              3-4 from psu 1amp to 1.5 will heat that sucker in 1-2 min.
              Use IPA to confirm
              • mattpd
                • Oct 2012
                • 302
                Sweet. A 18650 worked perfectly. Shorted cap found and removed which cleared up the board of shorts.
                How do I go about replacing it though? It's unmarked, so without some board view software I can't tell it's original value.
                • rs232killer
                  • Feb 2015
                  • 89
                  • Portugal
                  Hi
                  we use a Flir camera to find badcaps
                  regards
                  RS
                  • cyberhack
                    • Feb 2013
                    • 466
                    • Uk
                    I'll stick with the finger test,as them flir camera's are expensive.
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                    • Stephen
                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                      by Stephen
                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                      02-06-2025, 12:03 PM
                    • Victor Moreira Silva
                      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                      by Victor Moreira Silva
                      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                      Well, my decice specs are the following:
                      Model: Acer Nitro 5 AN517-54-55T5
                      CPU: Intel Core i5-11400H
                      GPU: NVIDIA GeForce GTX 1650
                      Motherboard: GH51G LA-L181P Rev:1c
                      The symptom:
                      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                      05-26-2025, 10:49 AM
                    • aaronkatrini
                      Help me find the short circuit on this WORKING Nvidia GTX1650
                      by aaronkatrini
                      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                      04-18-2024, 03:15 PM
                    • Geeker007
                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                      by Geeker007
                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                      01-28-2025, 03:31 PM
