Macbook pro 13 power button
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Now macbook turn on only when you disconnect battery and drain power ,then connect charger turn on automatic after charger is connected,I change new keyboard same so problem is on motherboard . Macbook works perfect once is turn on even charging battery ,restarting normally ,everything works perfect.
    Macbook pro 13 (early2011) A1278
  • macattack600
    • Aug 2011
    • 97
    Re: Macbook pro 13 power button
    Remove battery hold power button for 10 seconds wait 10 seconds but battery back in and connect charger when it starts up hold cmd-option+p+r .
    • ciki
      • Aug 2014
      • 132
      • Ireland
      thx try that and same thing
      • dellxps15
        • Feb 2014
        • 1585
        • italy
        new macbook pro i5 i7 when battery is not connected turn on automatically when u plug power supply. u have something wrong on power botton.
        check pin n°5 of keyboard connector and see how many volt u have and how many voltage u have when pressing power botton.
        • ciki
          • Aug 2014
          • 132
          • Ireland
          hi thx i get 3.4 v on pin 5 ,and I found when I short 2 pins beside smc turn on ,I think definitely need new keyboard again
          • gcomputers
            • Apr 2013
            • 509
            • Albania
            look this video for me function this method but you need to modify the power button
            https://www.youtube.com/watch?v=GNdaT-aUqns
            • themosttogain
              HP Envy 13-BA1565na with intermittent power button
              by themosttogain
              Hope someone can give me some suggestions on this because i'm at my wits end with it...
              I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
              Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
              07-12-2024, 03:03 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • reessi
              Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
              by reessi
              With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
              No corrosion any where!
              Tried a replacement power button off ebay and the same.
              Very occasionally it will work with the power button connected!
              Same results with or without the battery.
              Can it be a fault with the Audio board or the mainboard?
              The touch Id assembly connects through the Audio board first then to the Mainboard.
              Flex...
              06-26-2024, 03:31 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • TimeRabbit07
              Asus FX517ZC charges but power button does nothing
              by TimeRabbit07
              Hi all!
              I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
              Here are its various numbers and identifiers:
              Model short: FX517Z
              Model long: FX517ZC-HN114W
              SN: NANRCX01S57842E
              CN: 3SDB 12M
              MFD: 2022-10
              Motherboard model: DA0NJLMBAE0 REV E
              Symptoms:
              The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
              History so far:
              The...
              09-04-2024, 05:48 PM
