Component heating up
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Good day guys. I'm a little bit lost as of this moment I got and old Fujitsu Amilo laptop with a heating component. Motherboard has power but does not boot. Found IC U31 very hot after pressing power button.
    Please check attachment. As you can see I got voltage on all PINS. I notice pin no 8 is very high. and pins 3 and 4 are low. I already replace ic with same value. I laso removed c904 which I thought was faulty but same thing. Need to know if which pin is causing IC to heat up. thanks to all.
  • mariushm
    • May 2011
    • 3799
    Re: Component heating up
    That's a linear regulator:
    It works by dissipating the difference between input voltage and output voltage as heat, so it's natural that it would get warm.
    It could get hot if there's a component after the chip that uses a lot of current or a component that's faulty and causes a short circuit, forcing the linear regulator to output up to its maximum capability.
    Get a multimeter and check capacitors for shorts after the linear regulator, or maybe whatever is connected to that 1.05v VS is dead.
    If there's a short, it's not uncommong to see the regulator overloaded and showing a much lower output voltage than the confgured one, which seems to be the case here.
      • 31248
      one of the 4 output caps could be bad - or something it feeds not on that diagram.
      before you solder anythnig, repeat the test without the cpu & ram etc - just incase
      • lezsimply
        The Wanderer
        • 657
        • Philippines
        Thanks for the input. I forgot to mention that I found short on output rail. I already removed C281 and C358. C243 and C371 are empty. Short still there, don't know where +1.05vs goes after. I'm looking at Q45 as the output of +1.05vs. But not so sure. I attach schematic diagram. Thanks again for the help.
        • rookieme
          • Oct 2014
          • 399
          • Greece
          In order to find the short you have to supply the power rail with external power supply at 1V.
          The short will heat up and you're able to track it and remove the heated part.
          • lezsimply
            The Wanderer
            • 657
            • Philippines
            no lab psu for now. Does this have something to do with low reading on R785 and R786? Both have 37k ohms on my meter. Different from what is indicated on schematic. thanks again.
            • bilux
              uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
              by bilux
              I want to find a replacement for uP0109 8pins, and i found this parts:
              uP0109 is "2A Ultra Low Dropout Linear Regulator"
              RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
              FP6137C is "2A BUS TERMINATION REGULATOR"
              can replace uP0109​ by RT9199 or FP6137C ?
              11-01-2024, 12:00 PM
            • disorder
              HP 2311 display, 3.3v regulator fried, need help to replace
              by disorder
              hello,
              i have a hp display 2311 to repair, totaly dead
              on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
              i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
              thank you
              07-27-2025, 04:34 AM
            • EasyGoing1
              The best way to drive a heating element?
              by EasyGoing1
              I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
              What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
              This is the general setup that I have now.
              This is what the...
              01-25-2023, 11:29 AM
            • davidebeatrici
              Sony M851 MBX-217 no POST and restart loop
              by davidebeatrici
              Before proceeding with a component level repair, the usual troubleshooting process was followed:
              1. Disassemble and unplug everything except the power connector.
              2. Replace RAM.
              3. Replace CPU.
              4. Rewrite BIOS.
              Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
              After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
              I thought to myself "Well,...
              07-03-2025, 04:19 PM
            • Cemal Odabasioglu
              MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
              by Cemal Odabasioglu
              I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
              Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
              Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
              Observations...
              01-14-2025, 03:54 PM
