D270 not powering on
  • kazia
    • May 2015
    • 145
    • indonesia
    D270 ZE7 not powering on, no +3pvcu, no 3,3v/5v, no burn or hot ic, only got 19v .
    replace 88731 still the same. any suggestion?
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: D270 not powering on
    first check voltage at pin 8 and pin 17, usually like this 3.3v at pin 8 and pin 17 4.96v.
    4.96v that indicate there was problems.
    then check voltage pin 12 and pin 19 rt8223, if high then replace solid caps.
    common problem this series was leaked solid caps dc-dc 3.3vpcu/5vpcu
    today have managed fix it, just cause solid caps, better idea is replace with tantalum 220/330uf 6.3v
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      double post
      • kazia
        • May 2015
        • 145
        • indonesia
        yes, it was leaked caps....
        thanks broo..
        • Weelcup
          XPS 9520 not powering up. Solid orange led
          by Weelcup
          Hi friends
          I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
          I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can...
          10-20-2025, 04:22 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
        • valvashon
          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
          by valvashon
          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
          11-24-2024, 12:08 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • RetroComputingGrotto
          Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
          by RetroComputingGrotto
          I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
          As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
          What is your advice/opinion on whether or not on old(er)...
          04-03-2024, 08:30 AM
