XPS 9520 not powering up. Solid orange led
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Hi friends
    I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
    I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can measure it every where it should be present and it does. But the laptop is still not turning on. Now when I press the power button, it does blink orange led but it keeps solid orange during holding the power button, once I release the power button it goes. So it is technically not blinking but only lighting up while I keep holding the power button!
    I have never come across similar issues, although I saw this post on Reddit for someone who had exactly similar symptoms but ended up replacing the board.
    https://www.reddit.com/r/DellXPS/s/CKN6Qj6VA6
    Any suggestions?
  • reformatt
    • Feb 2020
    • 1494
    Start with motherboard part number and links to schematic/boardview if available. Laptops with USB-C charging usually have boost/buck power supplies so it should still provide your main power rail (roughly the voltage of the battery) with only 5V. When USB-C is 5V, it's in boost mode, when it's 20V it's in buck mode.
    If you aren't getting your main rail with 5V from USB-C, that's where you start. 20V often only gets negotiated when other ancillary power rails appear and you need the main power supply at least to be working for those to be generated.
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
      DELL Latitude 9520 Notebook 9000 Specification for Upgrade or Repair
      This specification for the DELL Latitude 9520 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9520 boardview and 9520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 9520...
      09-07-2024, 03:40 AM
      DELL Latitude 9520 2in1 Hybrid (2-in-1) 9000 Specification for Upgrade or Repair
      This specification for the DELL Latitude 9520 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9520 2in1 boardview and 9520 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
