MacBook pro 820-2889-a no ram detect
  • inspirim
    • May 2013
    • 282
    • Italy
    This motherboard does not detect a channel of the ram, while the other works well.
    a chip reballing N-Vidia has not solved the problem, connettoer ram looks good.
    you have any idea
  • diif
    • Feb 2014
    • 6978
    • England
    Re: MacBook pro 820-2889-a no ram detect
    I believe one of the slots uses BGA to attach to the motherboard. If it's had a reflow with the memory still attached then the weight causes the BGA to break free.
    • inspirim
      • May 2013
      • 282
      • Italy
      It was this defect even before reballing
      thanks
      • diif
        • Feb 2014
        • 6978
        • England
        Nobody else has worked on it before you ?
        • inspirim
          • May 2013
          • 282
          • Italy
          is some people have attempted repair
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • Flasman90
            Macbook Pro DFU Restore Issues
            by Flasman90
            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
            08-30-2025, 10:27 AM
          • PITERPENY
            MacBook 2141 problem with reballing a video chip
            by PITERPENY
            I encountered a problem with reballing a video chip. Tell me what I'm doing wrong that sometimes the balls don't form as they should? Bottom heating 240C, top 320C, I pour flux well. And the result is this. Any advice is important....
            08-31-2024, 03:40 AM
