Replace scratched phone screen and other question
  • Fast Alpha
    • Feb 2013
    • 245
    Hi again folks, how easy is it to replace a smart phone screen, and camera glass bit.
    Is it easy to repair.
    Also what do you use on a LAPTOP cpu, not thermal paste, where do you get it from the UK.
    http://www.hse.gov.uk/pubns/indg305.pdf
    • 31086
    Re: Replace scratched phone screen and other question
    you need to state the fone make / model
    as for "get it from the UK.", that's real funny.
    you get it from china via ebay!
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      As easy as eating popping corns... depending on the basket size and phone model
      ... or from UK on eBay
      • Fast Alpha
        • Feb 2013
        • 245
        WHAT THERMAL STUFF DO YOU PUT ON LAPTOP CPU ????????????
        Could you answer this other question too.
        This is the PHONE Samsung Galaxy S3 MINI
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          this is what i use
          http://www.ebay.co.uk/itm/Arctic-Sil...oAAOSwnipWVaed
          https://www.ifixit.com/Guide/Samsung...lacement/23219
          • Fast Alpha
            • Feb 2013
            • 245
            http://www.ebay.co.uk/itm/Blue-Samsu...AAAOSwYudXGfkJ
            Please be note: All the item will be tested 100% working fine before dispatched. before buy this item please make sure you are a special repair technician.
            Change this Part is not an easy job.
            the item (especial the flex ribbon is easy fracture) is easy to damaged during the fitting. please test the item first before glue it into your phone or frame.
            just connect the flex ribbon to mainboard connector. after test the item working fine and then fitting into your phone.
            we will not respond any faulty or damaged after the assembly fitting or glue into your devices.
            What I never done this before, the phone has a charging problem now!
            • brucetv
              • May 2015
              • 281
              • united states
              You probably damaged the charge port...good luck soldering that on.
              • SluggerB
                Help with trying to fix phone that is not charging (Pics inside)
                by SluggerB
                I have two TCL A30 phones.
                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                08-12-2024, 08:11 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • benek123
                RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
                by benek123
                I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
                The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
                When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
                I checked the EDID with the old screen - it is identical.
                What...
                09-24-2024, 03:28 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • kilog
                Snow on screen and no start Do I have to replace my CF53-MK2
                by kilog
                Hello friends,
                Last week when I tryed to start my CF53-MK2 it just stop starting
                and when it starts it displays snow and dansing and coloured lines on the sreeen as you can see in the attached video.
                Some time it may show the startup Bios screen for a 3 to 10 seconds and then immediatly starts to disply snow and coloured lines.
                I tested the RAM it is correct.
                I tried to hook the machine on a HDMI screen, nothing.
                I am not sure that the computer goes far to be able to show anything on an additional monitor.
                Please I need your...
                09-27-2023, 08:00 AM
