Snow on screen and no start Do I have to replace my CF53-MK2
  • kilog
    • Jan 2020
    • cameroun
    Hello friends,
    Last week when I tryed to start my CF53-MK2 it just stop starting
    and when it starts it displays snow and dansing and coloured lines on the sreeen as you can see in the attached video.
    Some time it may show the startup Bios screen for a 3 to 10 seconds and then immediatly starts to disply snow and coloured lines.
    I tested the RAM it is correct.
    I tried to hook the machine on a HDMI screen, nothing.
    I am not sure that the computer goes far to be able to show anything on an additional monitor.
    Please I need your advice: do I have to change my CF53 screen, or is it something bad with the motherboard.
    Best regards
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • benek123
    RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
    by benek123
    I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
    The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
    When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
    I checked the EDID with the old screen - it is identical.
    What...
    09-24-2024, 03:28 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • burbutsalos
    LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
    by burbutsalos
    Hello everyone.
    I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
    The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
    The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
    The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
    The effect is there even on a completely black screen.
    The screen...
    10-21-2023, 02:57 AM
