missing part on asus u31sg-rx061v
  • shuky
    • 49
    hello i have a broken jack and it broke a part from my board can some one
    tell me what is that part please ?
    the motherboard is u31sg
  • shuky
    • 49
    Re: missing part on asus u31sg-rx061v
    can i use the motherboard without the missing part ??
    • khaahk
      • Dec 2013
      • 760
      • Estonia
      Most likely yes.
      • ITSYSTEMSALBANIA
        • Mar 2015
        • 37
        • Albania
        Maybe is a capacitor.
        • kotnatan
          Banned
          • Apr 2014
          • 181
          • Ukraine
          pc6000 - 0.1uf/25v
          • shuky
            • 49
            thank you kotnatan will order the part and test .
            • shuky
              • 49
              yes working but no charge ... maybe from the fall never mind don't need to battery
              thank you
              • Djosla
                • Dec 2012
                • 246
                • Montenegro
                yes it is a capacitor...this does not affect charging at all you have different problem with it...
                • khabib
                  ASUS STRIX G531GT MISSING PM_SLP_SUS#
                  by khabib
                  Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
                  here what i measure already:
                  EC_RST# 3.3V
                  SRTCRST# 3v
                  +3VA_RTC 3V
                  RTCRST# 3V
                  ME_SusPwrDnAck 0V
                  AC_PRESENT 3.3 V
                  AC_IN_OC# 0V
                  PS_ON 3,3V
                  +3VA_DSW 3.3V
                  DPWROK_EC /R 3.2V
                  PM_BATLOW# 3.3V
                  SM_INTRUDER# 2.8V
                  PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
                  THat is can confirm PCH relate issue...
                  05-28-2024, 01:30 AM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                • madushanka 1234
                  MISSING PART NEED TO FIND ...HELP ms-16r41 rev 1
                  by madushanka 1234
                  ms-16r41 rev 1
                  PU7
                  ANYONE HELP ME TO FIND THIS COMPONNET...(​​​​​​​PU7)
                  I MISSING THIS PART RECENTLY..
                  I NEED TO FIND IC MODEL..AND SIMILER PART..
                  PHOTOS ATTACHED
                  THANKS...
                  02-11-2025, 09:09 AM
                • ShadowAi
                  ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                  by ShadowAi
                  Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                  Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                  After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                  03-15-2024, 10:46 AM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
