Asus X551CA no power and no led
Re: Asus X551CA no power and no led
ISSUE RESOLVED!!!!! As i suspected the bad mosfes qm3024 was shorted, used my past experience and picked an AO7410 from a hp donor board, NOW I GOT POWER, LED LIGHTS, AND FAN SPINNING...SUCCESS!!
My problem might not be the same as your but YOUR CHARGING CIRCUIT ALWAYS HAS TO BE CHECKED FIRST when no power issues arises.
good luckComment
good luckLast edited by speedypro; 06-29-2016, 05:45 AM.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
I accidently touched those two point, can someone help me, which part was shorted and is it possible to fix it???Comment
I have basic knowlage. It's not the first time i fixed motherboards and other stuff. Those times were the simple ones, but this time I just simply don't know there to start...Comment
Thanks, I'll try to replace itOne more question: Is it possible to use x551m motherboard on x551c laptop? My friend have one.
) and replacing the SIO/KBC fixed it, nothing else blew up.
For power on no display issue above flash BIOS, should work.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Sooo, can I use x551m instead of x551cIt seems that form is the same, just parameters of cpu, gpu and other changes.
i have 2 boards, each one had PQ8807 mosfet burned, after replacement board turns on, everything works except charging.
System detects charger and shows charging but no actuall charging is provided (no voltage from PL8801. ACOK and ILIM pins works as they should.
I must mention that i replaced BQ24725 with new one.
Any advice?Last edited by lord; 01-23-2017, 06:07 AM.Comment
Hi.
I need you're help. I have the same laptop but the problem is very strange. If i push power button the light goes on but shuts down in 2 second. If i try it like a 100 times then maybe it booths up.
Tried replacing the power adapter but is still the same.
Maybe you can point where to look for the problem.
Thanks.
BR CvetoComment
I'm facing the same issue, I unplug all power sources (2032 battery included), press the power button for 30 seconds and then wait a few minutes then plug the mobo battery and DC adapter and try to turn on the laptop. It turns on for about 20 seconds, it boots the BIOS config and immediately after a few seconds it turns off and won't turn on again for about 5 hours when doing the procedure I described in the beginning of this post.
I saw a russian video on youtube that says that there are mosffets that control voltage and changing them should fix the problem but I lack the experience to do such operation.Comment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... -
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
