In-circuit eeprom programming
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Since not desoldering the eeprom chip takes much less time, I was thinking about in-circuit programming. I have CH341A programmer, which works perfectly and I got myself a SOIC8 test clip. Paired those two and connected it to a HP Pavilion 15 eeprom.
    The problem is, that when I try to read from the chip, it only reads atleast 7 and up to 256 characters. No more, no less.
    Any idea what causes this problem and how can I fix it?
  • hansie55
    • Dec 2013
    • 254
    • Netherlands
    Re: In-circuit eeprom programming
    I bought this test clip with the CH341a and it works ok.
    You have to pay attention to the connection on the CH341a, that is not the same as the program says, but as on the pcb from the programmer.
    Also, the clip on the chip has to be very good placed, makes also a difference.
    http://www.ebay.nl/itm/381028670542?...%3AMEBIDX%3AIT
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Had the same clip but without the wiring. That I made myself so it is made correctly.
      And, it was placed very well because it read the first characters correctly. Problem was, it just did not read all of the characters. So maybe it works with some motherboards and doesn't work with others?
        • 31255
        you cant read a chip in circuit for 2 reasons.
        1: it's already hooked up to other chips that are putting voltage on it's data pins.
        2: it may be in parallel with other serial devices like temperature sensors.
        there is ONE possible way around this - on a working system.
        boot into the bios and leave the menu on the screen while your reading the chip.
        that will keep the cpu busy doing - not a lot.
        • sparker1
          • Sep 2011
          • 343
          I have the EZP2010 and always de-soldered the bios chip to re-program it but I read on another thread that you could do this in circuit with attachment clips. I ordered one and the results have been disappointing. I have never been able to get a chip to register with the programmer when using it with the clips in circuit and I guess stj has given the reason. But isn't this what the clips were made for?
          • TossDon
            AKA Masood
            • Jun 2013
            • 26
            I have TL866 programmer, it came with a adapter that has a interface chip on it, it looks cheap but works good, I also have the similar SOIC8 plain regular adapter without the interface chip, never was able to read completely using it. I think CH314 and TL866 are more the same but for the form factor, check their site to make sure you are using the right connector.
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              [QUOTE=stj;609586]you cant read a chip in circuit for 2 reasons.
              In circuit does not necessarily mean with power on, so system off and there is no voltage on no pin.
              I put the ch341a in usb with 5V supply and it reads the entire 8mb.
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                Indeed. I know it is possible (with power off). Just wondering why mine acted out.
                But since it takes a lot of time to get a good connection using the clip, I would say desoldering method is faster Or I'm just very bad with the clip.
                • R_J
                  • Jun 2012
                  • 9608
                  The usb +5 volt supply can't power the circuit you are connecting to, there are other conponents connected to the vcc of the eeprom, like the microprocessor and its memory etc. even with the units power being off
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    An update to this topic.
                    A year has passed and I tried it again on some more laptops. Now it seems to work perfectly. Maybe it depended on the laptop design or something.
                    And also, I am trying to build a tiny pogo pin SPI adapter which might be much easier to operate.
                    • SidneyCanadas
                      93C46 and 93C56 EEPROM
                      by SidneyCanadas
                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                      06-14-2023, 01:16 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • dmccul2698
                      Pioneer DEX-P99rs "No EEProm " diagnostic code.
                      by dmccul2698
                      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                      1). Understand the schematic and check the connections between the EEProm and DSP
                      2). Check the functionality of the EEProm
                      I don't know if this is the unit's problem but it's a place to start.
                      I have little to no electronic experience...
                      04-08-2024, 05:32 PM
                    • Instafixx
                      Macbook Display EEPROM Programming
                      by Instafixx
                      Namaste!
                      Recently while doing Macbook Display repairs - due to a mishap by the supplier, we found that certain Macbook LCDs are cross -compatible but have Brightness issues.
                      Some are DIM after start-up and some stay at Max brightness with the brightness control being disabled.
                      While speaking to my supplier they said that they can program the LCDs at the Factory so that the brightness issue was resolved.
                      I was wondering if there were a way we could do the same? I came upon a video online as well. Here is the link >...
                      01-18-2023, 10:36 AM
                    • ducky29
                      24C04 Eeprom programming?
                      by ducky29
                      Hello. I have to read a 24c04(404rp) eeprom msop8 package but currently don't have an adapter for it. I have read couple comments that claim that you can read by connecting only some pins of the eeprom, only serial data and serial clock. Has anyone tried this or is there any way how to read the data without desoldering the chip?
                      02-03-2021, 03:02 PM
