Apple Macbook pro A1286, wery slow
    Re: Apple Macbook pro A1286, wery slow
    it must restart 2 times
      i try this , after 3 restarts i stop pressing, but no fix.
        for me it could be a bad intel bga that need reballing (not reflow) , but let's wait some idea from other people.
          dellxps wich intel bga you are meaning ? HM ?
            Originally posted by angel-boy View Post
            here is the temperature, sistem have like a lag, and fan full speed
            can give a link for this program ?
            board is 820-2915-b
            graphic 216-0809000
            I dunno, because the temp readings look normal, but it still seems to act like it falsely detects a CPU overheat, unless the problem is with the GPU sensor that makes it constantly be underclocked.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              board is 820-2915-b
              graphic 216-0809000
              It's called ASD Apple Service Diagnostics. http://www.dannydullin.com/apple-ser...eference-list/
                can someone help me with asd apple service program ? to download ?
                i replace the graphic chip and the same problem .
                  if don't install the right driver for amd chip after refreshing os, the performance is sluggish.
                    Hi
                    I had a similar problem, Apple hint
                    Remove Battery and try
                    Remove odd and try
                    Replace hdd cable and try
                    Hope it helps
                    Regards
                    RS
                      In order to tell you the correct asd I need to know the exaxt model [mid 2010 etc].
                      Please check and post it here.
                      Also you can try smc reset [left shift + left control + option + power button]
                        Hi Friends I need the BIOS dump for this Macbook A1286 the logic board code 820-2915 B, can anyone help me plesae
                          missing sensors
                          820-2915-B
                          test asd
                          Each ASD has two parts:
                          1. ASD EFI – low level hardware tests.
                          2. ASD OS – OS level hardware tests.
                          This page explains how to prepare, create and run ASD.
                          ASDs are available ONLY for certified Apple technicians but… if you search persistently you can find them on the Internet.
                          The following list will help to figure out which ASD test your machine requires.
                          ASD 3S108
                          iMac (Early 2006 17-inch)
                          iMac (Early 2006 20-inch)
                          MacBook Pro (17-inch)
                          Mac mini (Early 2006)
                          MacBook (13-inch)
                          iMac (Mid 2006 17-inch)
                          iMac (17-inch Late 2006)
                          iMac (17-inch Late 2006 CD)
                          iMac (20-inch Late 2006)
                          iMac (24-inch)
                          ASD 3S116
                          MacBook (13-inch Mid 2007)
                          MacBook Pro (15-inch Core 2 Duo)
                          MacBook Pro (17-inch Core 2 Duo)
                          MacBook (Late 2006)
                          MacBook Pro (15-inch 2.4/2.2GHz)
                          MacBook Pro (17-inch 2.4GHz)
                          iMac (24-inch Mid 2007)
                          iMac (20-inch Mid 2007)
                          Mac mini (Mid 2007)
                          ASD 3S123
                          iMac (20-inch Early 2008)
                          iMac (24-inch Early 2008)
                          MacBook (13-inch Early 2008)
                          MacBook Pro (15-inch Early 2008)
                          MacBook Pro (17-inch Early 2008)
                          Mac Pro (Early 2008)
                          MacBook (13-inch Late 2007)
                          ASD 3S132
                          MacBook Air (Late 2008)
                          MacBook (13-inch, Aluminum, Late 2008)
                          MacBook Pro (15-inch, Late 2008)
                          MacBook (13-inch, Early 2009)
                          MacBook Pro (17-inch, Early 2009)
                          iMac (20-inch, Early 2009)
                          iMac (24-inch, Early 2009)
                          Mac Mini (Early 2009)
                          Mac Pro (Early 2009)
                          iMac (20-inch, Mid 2009)
                          MacBook Air (Mid 2009)
                          MacBook (13-inch, Mid 2009)
                          MacBook Pro (13-inch, Mid 2009)
                          MacBook Pro (17-inch, Mid 2009)
                          MacBook Pro (15-inch, Mid 2009)
                          MacBook Pro (15-inch, 2.5.3GHz, Mid 2009)
                          ASD 3S138
                          MacBook (13-inch, Mid 2010)
                          MacBook Pro (13-inch, Mid 2010)
                          MacBook Pro (17-inch, Mid 2010)
                          MacBook Pro (15-inch, Mid 2010)
                          MacBook (13-inch, Late 2009)
                          iMac (21.5-inch, Late 2009)
                          iMac (27-inch, Quad Core, Late 2009)
                          Mac mini (Late 2009)
                          ASD 3S139
                          Mac mini (Mid 2010)
                          ASD 3S140
                          iMac (21.5-inch, Mid 2010)
                          iMac (27-inch, Mid 2010)
                          ASD 3S142
                          MacBook Air (13-inch, Late 2010)
                          MacBook Air (11-inch, Late 2010)
                          ASD 3S143
                          Mac Pro (Mid 2010)
                          ASD 3S144
                          MacBook Pro (13-inch, Early 2011)
                          MacBook Pro (15-inch, Early 2011)
                          MacBook Pro (17-inch, Early 2011)
                          ASD 3S145
                          iMac (27-inch, Mid 2011)
                          iMac (21.5-inch, Mid 2011)
                          ASD 3S146
                          MacBook Air (13-inch, Mid 2011)
                          MacBook Air (11-inch, Mid 2011)
                          Mac mini (Mid 2011)
                          ASD 3S147
                          iMac (21.5-inch, Late 2011)
                          ASD 3S148
                          MacBook Pro (13-inch, Late 2011)
                          MacBook Pro (15-inch, Late 2011)
                          MacBook Pro (17-inch, Late 2011)
                          ASD 3S150
                          MacBook Pro (13-inch, Mid 2012)
                          MacBook Pro (15-inch, Mid 2012)
                          MacBook Pro (Retina, Mid 2012)
                          MacBook Air (11-inch, Mid 2012)
                          MacBook Air (13-inch, Mid 2012)
                          ASD 3S152
                          iMac (27-inch, Late 2012)
                          iMac (21.5-inch, Late 2012)
                          Mac mini (Late 2012)
                          Mac mini Server (Late 2012)
                          MacBook Pro (Retina, 13-inch, Late 2012)
                          ASD 3S155
                          MacBook Pro (Retina, 15-inch, Early 2013)
                          MacBook Pro (Retina, 13-inch, Mid 2012)
                          MacBook Pro (Retina, 13-inch, Early 2013)
                          iMac (21.5-inch, Early 2013)
                          ASD 3S156
                          MacBook Air (11-inch, Mid 2013)
                          MacBook Air (13-inch, Mid 2013)
                          ASD 3S159
                          Mac Pro (Late 2013)
                          ASD 3S162
                          MacBook Pro (Retina, 13-inch, Late 2013)
                          MacBook Pro (Retina, 15-inch, Late 2013)
                          MacBook Pro (Retina, 13-inch, Mid 2014)
                          MacBook Pro (Retina, 15-inch, Mid 2014)
                            It'll most likely be a sensor issue, NOT a gpu/reballing issue. Louis Rossmann had a video on this just recently;
                            https://www.youtube.com/watch?v=e4zo8mVpxvc
                            https://www.youtube.com/watch?v=sWdyfsh8hpA
                            YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                            FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                              valid link to donwload ASD 3S144
                                hello, does anyone have the bios (.bin) file of the macbook pro 15 "A1286 mid 2009 with SST25VF032B EMC 2324 chip?
