Apple Macbook pro A1286, wery slow
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3598
    • slovakia
    Hello.
    Have this Apple Macbook Pro A1286 that have bad balls under GPU. After reball image come ok but whole system is WERY slow. it is slow even with another system. any help in this?
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Apple Macbook pro A1286, wery slow
    flash the bios, maybe bad dump
    post the whole motherboard code; maybe i have a dump file
    • angel-boy
      • 550
      • Romania
      i have the same problem ,
      after reflow , the sistem is very slow , and fan is at full speed
      any help ?
      • angel-boy
        • 550
        • Romania
        Any help please
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds like a thermal sensor short.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • angel-boy
            • 550
            • Romania
            how can i found the sensor ?
            • diif
              • Feb 2014
              • 6978
              • England
              There is a disk floating about ATT I think its called. Boot to that and it checks all the sensors.
              • angel-boy
                • 550
                • Romania
                here is the temperature, sistem have like a lag, and fan full speed
                can give a link for this program ?
                board is 820-2915-b
                graphic 216-0809000
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  board is 820-2915-b
                  graphic 216-0809000
                  I'm out at the moment but I'll try and remember to post when I'm back. It was a torrent if that helps at all.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    thats seems bad gpu KTM , specially macs are week in that behaviour , usually once gpu start to fail all internally start to fade out as well , the best option you got here is to replace the gpu KTM , also make sure you insert same chip , if its 128 bit USE 128bits , or you might have future issues
                    • angel-boy
                      • 550
                      • Romania
                      what KTM means ?
                      i make reballing to chip , and the same problem . you belive that i need to change gpu ?
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        yes , indeed gpu chip can slow down your system once they are in life end . macs are expert on thaat issue , gpu replacement solve in the moment this issue !
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          KTM =KTMMOTOCROSS (user in the forum)
                          • angel-boy
                            • 550
                            • Romania
                            im mad, becase before reflow, or reballing, the fan works normal.
                            or how can i modify to run only processor graphics ?
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              yes , you killed gpu ,
                              • alas3376
                                • Nov 2011
                                • 382
                                • BENIN
                                u need to change the gpu; highpulse is right
                                • angel-boy
                                  • 550
                                  • Romania
                                  thats why have a lag and fan full speed.
                                  cannot be the memorys ?
                                  • dellxps15
                                    • Feb 2014
                                    • 1588
                                    • italy
                                    fan is controlled by smc. have u done a pram reset after reflow or gpu reballing ?
                                    when a pc is slowind down generally it's intel chipset. (had an hp notebook that was slowing down and after a day it went dead. after reballing these small intel bga it went back ok to normal.
                                    • angel-boy
                                      • 550
                                      • Romania
                                      yes, try reset nvram ,
                                      now i reset pram ? tks
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        command +control + p +r and press ON button , but still leave pressed command control p + r until it restart again , once it restart stop pressing the keys
