incredible CQ56
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    incredible CQ56
    Today I had a hp CQ56-220SL which I had repaired a month ago because does not charge and would not turn on
    BIOS flashed all ok .
    Had the same problem today. flashed bios ok turn on . I closed the laptop put the battery on ,it turned on and locked on the logo hp.
    I removed the battery, and do not charge more the same problem.
    Reopened flash bios again with another chip 1mb (because I thought is defective the chip) ok charge again turn on all ok .
    Closed again when i put the battery blocked again
    no charge no turn on dead
    flashed again for the third time ,
    I FIND THE PROBLEM IS BAD BATTERY WHEN I PUT IN HIM CORRUPT THE BIOS, WITH ANOTHER BATTERY FUNCTION NORMALLY.
    Finally closed turn on without battery function perfectly.
    I noted on the battery for the client, do not use more dangerous.
    sorry for my english if i am not clear the fault is of google translate.
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Re: incredible CQ56
    Mu me ka ndodh me nje laptop fujitsu qe nuk ndizte fare sepse kishte baterin e demtuar ty te pakten tu paska ndez.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5069
      • New Zealand
      Re: incredible CQ56
      Interesting. Did you find out why the battery was corrupting the BIOS?
      Did a new battery solve the problem?
      -David VanHorn
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        Re: incredible CQ56
        With new battery work fine.
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          Re: incredible CQ56
          Ndez por menjehere prishte biosin e Çuditshme. e kemi hap e mbyll dje tre here. ku punon ti un jam ne shkoder.
          • ITSYSTEMSALBANIA
            • Mar 2015
            • 37
            • Albania
            Re: incredible CQ56
            Un punoj ne tiran.
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              Re: incredible CQ56
              U have to go step by step when closing.u can close without connectant mouse for exemple ,
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                Re: incredible CQ56
                today i got an hp notebook dv5 with daqt8hmb mainboard. pc was reballed of nb and worked fine. as i mounted all back, plug in battery power on and i got the 2 blinking mean corrupted bios. put psu and pc power on ok. battery is almost charged, so that was strange. put another battery and charged it a bit and noticed battery inductor got a bit hot. after it was charged to let me power on laptop, it still did the 2 blinking caps (mean bios corrupted). if i use psu only or battery+psu pc power on ok.
                so i checked bios voltage with battery only and with battery+psu and result are these:
                with only battery voltage on pins:
                1-3.3
                2 0
                3 3.3
                4 0
                5 0
                6 0
                7 3.3
                8 0
                with battery + psu:
                1 0.17
                2 1.5
                3 3.3
                4 0
                5 0.23
                6 0
                7-8 3.3
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Re: incredible CQ56
                  You should start another topic. But try cleaning RAM slots with IPA. If no go, the NB is faulty and needs to be replaced, reballing only fixed it for a little bit. Had the same issue on a couple dv5 boards. Replaced NB and all ok.
                  A working TV? How boring!
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Re: incredible CQ56
                    QFT. Sounds like you need to reseat HDD and RAM, just in case of poorly seated RAM.
                    And there's a good chance it's the southbridge, if reseating don't stop the lockup at the BIOS logo.
                    BTW, I had a CQ 61 that suddenly fails to boot, with code #1.
                    Failed with a blink-of-death like a plasma tv, HP's version of the RROD!
                    (On April 19, 2013, was able to restore Windows 7, but the Athlon II CPU wasn't stable at stock clock without a cooling mat!) (Was found dead in November, 2014)
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1489
                      • portugal
                      Re: incredible CQ56
                      you got a problem on circuit battery detection.
                      this is clear obvious since pinnout for bios have a bad result , even for SPI channel you got 0 . now bat circuit protection works along a bunch of transistors that receive info from KBC to activate or not certain gate of does transistors .
                      and since KBC found a anomaly in this OCP OVP circuit , KBC will not work correctly , making you to not have correct spi values on the bios chip itself .
                      you got there a pretty nice challenge not very hard , but a patience work , you must get the schematic for you can follow each independent signal /voltage on the battery circuits .
                      alltough chek that this battery is ok ...
                      as also you stated , you mention you notice the inductor to get hot , well it will get a bit hot while charging . but if its to hot , defenitly you got prroblem on OCP circuits
                      if you stick around with this machine on your lab , next week i will be back from vacations , and i can help you out to reach a solution
                      keep up the good work
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
                      • ruletero
                        Acer a515-43 low battery charge voltage
                        by ruletero
                        Hi
                        Acer A515-43
                        LA-H801P
                        Fail: Does not charge battery, has low voltaje on connector.
                        Laptop didn't want to turn on, only charge led blinked.
                        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                        10-24-2022, 02:31 PM
                      • Klevjetack
                        Charge a L19D3PDA battery externally from the laptop
                        by Klevjetack
                        Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                        03-05-2024, 07:26 AM
                      • razenxd
                        How can I charge that battery pack?
                        by razenxd
                        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                        Now, I have noticed a few things.
                        The "dead" battery, while connected to charger and NOT Charging will...
                        12-05-2024, 06:11 AM
                      • mkdj
                        What should I do after having flashed a BIOS?
                        by mkdj
                        Dear all,
                        I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
                        Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
                        09-09-2025, 09:45 AM
