Samsung powers on with battery, no power with charger.
  • diif
    • Feb 2014
    • 6978
    • England
    Hello, i have been given a faulty Samsung NP300ESC laptop with a Scala3-15/17crv motherboard to look at. The customer said the old charger died so they bought a new one which was universal. Since then there have been powering on issues. I have measured the voltage on this and it's nearer 20v not the 19v it says. Either it's this or the previous charger have damaged something i think.
    There are no LEDs lit when i plug in my power supply and pressing the power button does nothing. However if i plug in a battery the laptop powers on fine.
    There is 19v on VCC of BQ735 up near the battery connector, but without a schematic i'm struggling a bit. Can anyone point in the location of where i need to be testing please ? Thanks
  • dj_ricoh
    • 2073
    Re: Samsung powers on with battery, no power with charger.
    first! like you need to be 100% sure that the DC jack its ok.
    90% of the Samsung i do they all bad there and even with cables!
    • angel-boy
      • 550
      • Romania
      See photo , check there, you have 2 i.c , one is shorted .
      • Life Goes On
        • May 2014
        • 264
        • Curacao
        I don't think it gone be dificult to solve the problem, that gone be for sure in the power line circuit, but you gone need the schematic to solve that.
        The Night Drop Down, I Will Keep Try Until..., You Never know.
        Dushi Kòrsou, Nos Tei.
        • dj_ricoh
          • 2073
          take it of and trace it with the multimeter where it comes from.
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            agree with you
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              Two fet or dual fet in between 5v and 3v power ic
              one of those gone wrong
              sigpic
              • diif
                • Feb 2014
                • 6978
                • England
                Thanks for your replies.
                I have checked the dc socket. I get power on the board from the centre pin, so i know that is fine.
                I checked under the tape as indicated by angel-boy and found the 2 ics.
                with markings 7200 on one and 9402ygt on the other.
                I found no shorts to ground or to its other pins and have measured the voltages.
                AON7200
                S-75-135mv constantly fluctuating
                G-50-126mv constantly fluctuating
                D-18.24v stable
                9402gyt
                S-60-130mv constantly fluctuating
                G-60-130mv constantly fluctuating
                D-1.03v stable.
                • gcomputers
                  • Apr 2013
                  • 509
                  • Albania
                  I repaired Np350E
                  I found the second 9402 gyt is shorted to measure better to remove it from board , i ordered it on ebay replaced and the laptop works fine.
                  • angel-boy
                    • 550
                    • Romania
                    is a simple repair.
                    Hope that helps you !
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Yes, a great help, thank you.
                      A little tinier than normal but i think i'll manage. I just need to see if the customer will wait for them to arrive from China as i can't find any UK suppliers.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        The parts arrived and i soldered into place. However during the soldering i managed to knock off and lose a small ceramic cap, just above the two ics.
                        Any idea on a value ? Thanks.
