Compaq620 no 5v 3v in coil.
  • nazrul145
    • Jan 2014
    • 335
    • BD
    Hello friends, problem with compaq, its U6000 pin 8=3.3v and pin17=5v.
    but no voltage in L6001 and L6000.
    Flash bios also same. Change U6000 also same.
    U6000 pin1 and 2= 0.7v
    L6000 resitance to
    gnd=18K
    and L6001 to ground=1.1k
    any idea please..
  • dj_ricoh
    • 2073
    Re: Compaq620 no 5v 3v in coil.
    check u6009_A and B all pins
    • dj_ricoh
      • 2073
      yes! do you got any short on L6000 or L6001?
      • nazrul145
        • Jan 2014
        • 335
        • BD
        Thanks for reply. No short found from ground to
        Coil.
        • saularciga
          • Feb 2014
          • 55
          • mexico
          Measure voltages en Q6005.
          KBC_PWR_ ON . do you have 3.3 v?
          If press power what voltajes have in Q6004?
          • nazrul145
            • Jan 2014
            • 335
            • BD
            Kbc_pwr_on 3.3v ok.
            • saularciga
              • Feb 2014
              • 55
              • mexico
              Open PAD6005 and PAD6004 , press power and measure voltages en L6000 , L6001 .
              Check Mosfet Q6007,08,09 ,10.
              U6000 is activad for the pins 6,1
              • nazrul145
                • Jan 2014
                • 335
                • BD
                I will check tomorrow because now I am in house.
                • saularciga
                  • Feb 2014
                  • 55
                  • mexico
                  Make this.
                  Measure voltages of U6009.
                  On pin 1 and 7 should be 3.3 V
                  check Q6009 and Q6010 , these MOSFET are connected to +VBATP, is very easy to faill
                  • nazrul145
                    • Jan 2014
                    • 335
                    • BD
                    Thank you. I didn't understand what you mean.
                    Only understand q6005 pin 4, 3 and 6,1 should short. If so then I will let's you know tomorrow.
                    • saularciga
                      • Feb 2014
                      • 55
                      • mexico
                      Only understand q6005 pin 4, 3 and 6,1 should short. If so then I will let's you know tomorrow[I][/I]
                      Make these connections for work force U6000
                      • dj_ricoh
                        • 2073
                        he said to desolder the pads!
                        there are some jumpers on board that are soldered! with JPAD name!
                        you take the solder out with wick and recheck voltage on coils
                        • nazrul145
                          • Jan 2014
                          • 335
                          • BD
                          i have short q6005 pin3,4.
                          then power up, after two times again same.
                          Then i short pin 3,4 and 6,1.
                          But same no 5v 3v on coil.
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            voltage at pin 13 of U6000?
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              Originally posted by saularciga
                              Make this.
                              Pin 1 and 6 should be between 0,5 and 2v (There is an internal 10uA current source from VREG5 to ENTRIP1 and ENTRIP2) in order to have +3va and +5va. If you short the pins of Q6005 (short to ground) you will never have the above voltages.
                              Check the resistance on pins 8 and 17 of RT8205 (and also voltages)
                              • nazrul145
                                • Jan 2014
                                • 335
                                • BD
                                pin 8 and 17 have 3.3v and 5v.
                                • dycc
                                  Vision
                                  • Nov 2011
                                  • 625
                                  • Côte d'Ivoire
                                  agree with you Atsio
                                  what is voltage on pin 1 and 6 ??????
                                  sometime bad ESR cap can cause theses types of issue .
                                  i mean C6026 and 6027 cap
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    Remove Q6005 and check if you have voltage on pins 1 and 6 of RT8205 (what is the resistance on those pins with and without Q6005)
                                    • dycc
                                      Vision
                                      • Nov 2011
                                      • 625
                                      • Côte d'Ivoire
                                      after Atsio's checks and if you don't have ESR meter just solder this cap(attachment) in parallel to C6027 and C6026 .
                                      give result
                                      • nazrul145
                                        • Jan 2014
                                        • 335
                                        • BD
                                        After remove q6005 U6000,
                                        pin1= 0.7v
                                        pin6=0.8v
                                        with and without q6005 resistance of U6000
                                        pin1=71k
                                        pin6=81k
                                        • chth96
                                          How can I test coil whether it is really broken or not?
                                          by chth96
                                          I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                                          I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                                          I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                                          I want to replace this round black fuse and unidentified coil if it got broken.
                                          02-20-2024, 01:07 AM
                                        • waterchill
                                          What part is this coil from a MacBook A2681 ?
                                          by waterchill
                                          Hi everyone
                                          I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                                          So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                                          IAny ideas? It is from a MacBook A2681
                                          Thank you...
                                          08-08-2024, 01:46 AM
                                        • Gjackson
                                          ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                                          by Gjackson
                                          Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                                          01-13-2024, 10:34 AM
                                        • chth96
                                          How Can I identify IFT coil?
                                          by chth96
                                          I have a CD unit which is came from saturn game console.
                                          It always perceived Any retail CD or CD-R as Audio-CD.
                                          Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
                                          I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
                                          I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
                                          Is there any way to identify its frequency in order...
                                          11-11-2022, 05:31 AM
                                        • lerom
                                          PowerEdge R740 coil resistance
                                          by lerom
                                          can anyone measure the resistance on coil L12 3.3V (near USB, EMMC chip) and coil L46 1V near CPU1 ?
                                          thanks....
                                          03-23-2025, 02:21 AM
