WD hardisk data recovery
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hello every one
    guys i have a external WD hard disk 500 gb that was protected by password . owner of hard disk format the all disk because he forget the password and lost all data . now he want his data back . i tried many software of recovery but fail. like .1 pareto logic data recovery. 2 MiniTool Power Data recovery
    Anyone have solution for this ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: WD hardisk data recovery
    Do you know how the data was password protected ? I doubt it's possible though.
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      not data.. hdd was proctored by bitlocker . as the owner of hard disk say .
      when the parson bring hdd there was no password .
      • diif
        • Feb 2014
        • 6978
        • England
        The data was originally encrypted with bitlocker then the drive formatted to wipe the drive ? The formatted data is still encrypted.
        • innocentforeign
          innocentforeign
          • Jun 2013
          • 172
          • KSA
          thank you for reply
          can you tell me how to bring back encrypted data ?
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            1. if it is protected by bitlocker, then there is no way to recover the original data from the encrypted data, unless the owner remembers the key (or password) used to encrypt the drive.
            2. if the owner formatted the hard drive, and haven't done any write operations on the drive, i think the encrypted data can still be recovered from it. Try any UNFORMAT utilities. However, you still need the key the owner used to encrypt the drive to be able to get the unencrypted data.
            Look at these reference, it might help you:
            http://www.thewindowsclub.com/recove...ncrypted-drive
            • magictouch
              • Apr 2021
              • 108
              • united kingdom
              I have accidentally formatted the Seagate harddrive, is there any way to unformat the hard drive or any good software to get the data back..
              have tried lazesoft data recovery, and I managed to get the data but I cat open any of the recovered file I get an error file type not supported, tried to open the files in mac aswell but same error.
              i will appreciate any help.
              Regards
              • mon2
                • 14673
                DO NOT perform any writes to this formatted drive. Use it ONLY as a slave drive in an attempt to recover the lost data.
                Then run a tool like this one:
                https://www.easeus.com/ppc/format-re...a-hard%20drive
                There are many others on the market but keep testing till the tool can see your data.
                Plan B is to seek out the help of the drive manufacturer - they have professional data recovery services but can be $$$ - $1k++ is not uncommon. Best to get a quote.
                • magictouch
                  • Apr 2021
                  • 108
                  • united kingdom
                  I can see the data with with 1 or 2 softwares but they are asking for a lot of money, So there is no free software which can be helpful, or cheaper?
                  • mon2
                    • 14673
                    Which software shows you the data ?
                    • kingiii
                      Possbility of data recovery, is it true?
                      by kingiii
                      Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                      07-02-2025, 02:29 PM
                    • mkdj
                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                      by mkdj
                      Dear all,
                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                      Here the steps I have taken to fix the laptop:
                      - downloaded latest BIOS from Lenovo Website...
                      10-18-2025, 03:43 AM
                    • DoOm86
                      Swap nand flash smartphone for data recovery
                      by DoOm86
                      Hello everyone.
                      I would like to know more about the following topic:
                      Nand flash on smartphone for data recovery.
                      I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                      But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                      How does it works? How do I know if data are encrypted or where is the key?
                      I know there are also very expensive external socket where you can put the nand flash in...
                      08-20-2023, 07:10 AM
                    • abajor
                      Attempting Data Recovery WD20EARS series HDD Reads as 0 byte drive.
                      by abajor
                      I was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
                      I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
                      As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
                      I'm assuming that the armature is no longer functional internally so no data can...
                      05-18-2024, 08:35 PM
                    • welcometoo
                      acer nitro 5 AN515-55 no display / caps lock
                      by welcometoo
                      Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                      model: nitro 5 an515-55
                      motherboard part number: GH51M LA-K862P Rev: 1A
                      i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                      i flashed new bios also ec(ene kb9022) the same result .
                      disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                      07-05-2025, 11:11 AM
