DV6-2010SV turn on only one sec
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi i have this model it s turn on one second, so not start i flashed the bios reflowed NB ati and the same problem .
    What do you think the nb is dead ?
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: DV6-2010SV turn on only one sec
    change Cpu and measure Cmos battery voltage it has to be above 3.0 V.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Changed Cpu (same model) , the voltage on cmos batt is 3.11V , on bios chip a have the just voltage 3.3v , 19v on board is present .
      • Life Goes On
        • May 2014
        • 264
        • Curacao
        I think you have to replace the NB chip, but first try to reflow the SB and see what it does.
        • dj_ricoh
          • 2073
          reball or change the AMD Graphic chip
          • gcomputers
            • Apr 2013
            • 509
            • Albania
            Thanks to All for the reply i just ordered , the NB for my experience with reball this model in 3 reball only one worked i think is to sensitive with temp.
            Anyway i will tell you when i replace the NB .
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3592
              • slovakia
              u use too hight temp or too much power. ati igp is most reballed ic
              • sopik78
                • Nov 2013
                • 517
                • Czech Republic
                It could be problem on 1.1V and 1.2V rail, try to read voltages here when it starts for that 1sec. If you will not measure 1.2V, try to change PU1, PQ41, PQ42 and post what happen.
                • tata123
                  • Nov 2013
                  • 104
                  ohhh Shkodran nrroj mosfetat ose testoj a jan ne rregull, mosfetat jan afer RAM Slotit.
                  A eshte modeli me Intel a AMD?
                  • gcomputers
                    • Apr 2013
                    • 509
                    • Albania
                    model amd
                    • gcomputers
                      • Apr 2013
                      • 509
                      • Albania
                      yes 1.2v is present , pq41 not have voltage , arround PU1 i have 5v ,
                      • gcomputers
                        • Apr 2013
                        • 509
                        • Albania
                        SOLVED SOLVED SOLVED
                        Big THANKS to SOPIK78
                        PQ41 do not have voltage i checked it without charger this chip It seems to be ok, but with charger on it s shorted with ground. Changed it and the laptop power on normaly.
                        Thanks to ALL
                        • Ramee
                          • Jul 2014
                          • 218
                          • Israel
                          Please share if you have the schematic diagram. Thanks!
                          • sopik78
                            • Nov 2013
                            • 517
                            • Czech Republic
                            Common problem on these scraps.. On DV5 as well. It is not necessary to do reball at the first time
                            Schematic could be like this one
                            • Ramee
                              • Jul 2014
                              • 218
                              • Israel
                              Thank you!
                              • Life Goes On
                                • May 2014
                                • 264
                                • Curacao
                                good to hear that you fix it.
                                • dqtech
                                  lenovo thinkpad t420 wont turn on when cmos battery attached
                                  by dqtech
                                  please help...this lenovo thinkpad t420 early problem is short 19v...after replace short capacitor all working fine...but, when i attach cmos battery on motherboard this laptop wont turn on, power button not respond....it only work without cmos battery....power button and cmos battery is in good condition...i try replace new cmos battery but problem still persist...any idea?...
                                  06-16-2023, 03:56 AM
                                • HammyCheesy
                                  Lenovo ThinkStation P720 BIOS Request
                                  by HammyCheesy
                                  Hello all,
                                  I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                  When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                  Type: 30BB
                                  Model Number: S03600
                                  S/N: MJ07N68C
                                  Things I have tried:
                                  1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                  2. Attempted to boot with just a single CPU...
                                  04-11-2025, 01:02 AM
                                • letsfixthis
                                  Acer VN7-791 - Flashed cleaned BIOS - Laptop wont turn off
                                  by letsfixthis
                                  Hey,
                                  I have been trying since 2 days to get this working.
                                  The Acer VN7-791 had the 30 Minutes shutdown issue.
                                  Therefore I desoldered the BIOS, cleaned the ME Region (with the Win-Raid guide) and Flashed the Version again.
                                  It seems to have solved the reboot issues.
                                  But unfortunately now I cannot turn off the computer anymore. It just reboots when I do it via Windows 10 or the Power Button. Only thing working is hard Reset via long press of the Power Button.
                                  I tried to install an older Version of Mangement Engine...
                                  10-13-2023, 04:29 AM
                                • robante15
                                  Acer Aspire 4520 won't turn on after reboot
                                  by robante15
                                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                  If I remove the...
                                  04-06-2024, 06:50 PM
                                • RdeveLabs
                                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                  by RdeveLabs
                                  To all the members here...
                                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                  05-05-2025, 04:59 AM
