Sony PCG-4121EL- VPCSA390X two seconds to death
  • tibimakai
    • Jan 2012
    • 3680
    My boss, gave me his laptop, because it would not work anymore.
    When I push the start button, the green LED turns on for two seconds, I can hear something spinning up for those two seconds, than it shuts off.
    Battery seems like it's charging, LED is on when it is plugged in. After a while the the charging LED goes off, I'm guessing the battery is fully charged.
    I have tried starting without battery, same thing happens.
    My boss is telling me, that it wasn't overheating. It happened, suddenly. A day before, it was still working.
    I have tried another power adapter and the result is the same.
    It seems like wants to start, but because of some sort of error it shuts off.
    Any help, would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony PCG-4121EL- VPCSA390X two seconds to death
    I have pulled the BIOS battery and reassembled it(roughly). Then the laptop turned on(green LED turned on and stayed on) and the fan started spinning, but very-very fast. That is, all it does. If I move the top cover(keyboard), than I see something on the LCD, like the backlight is turning on and off.
    This whole issue, it could be from the backlight also? Bad LED in the backlight and the laptop doesn't turn on?
    • dj_ricoh
      • 2073
      • uk
      find fuse F16; test it if its bad replace it or bridge a wire.
      if not post some picture of the board.
      • tibimakai
        • Jan 2012
        • 3680
        That fuse, is for the backlight and it's on the motherboard? There are separate boards in this laptop.
        • dj_ricoh
          • 2073
          • uk
          try to find it because its direct connected to the lvds connector to the screen ON the mainboard.
          • tibimakai
            • Jan 2012
            • 3680
            I'm at work, right now. I will do that, when I get home. Thanks for now.
            • tibimakai
              • Jan 2012
              • 3680
              It seems like, it's very sensitive connector, or one of them did not plug in well enough, because after playing with it for a while, it just started right up.
              After moving boards a bit(trying to connect a HDD), it did not turn on again.
              So I guess, I could put it together, but I have to be super cautious, when I plug in all the connectors.
              I will let you know about the outcome.
              I have found a metal stand-off ,from the second heatsinked processor(not sure is the graphics or GPU) that it came off(it was lifted out, of the PCB's hole), from the PCB.
              • tec3000
                Sony LED 65X9005A shuts down after few seconds - looking for help
                by tec3000
                Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                03-20-2024, 07:29 AM
              • mauda
                Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                by mauda
                I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                05-21-2023, 11:56 PM
              • chaos-theory
                Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                by chaos-theory
                I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                03-14-2025, 05:37 PM
              • solveit68
                Lenovo L580 20LW-0010GE shuts down after a few seconds
                by solveit68
                Hello together,
                I am hoping for some tips here to repair a notebook.
                The notebook has following issue:
                After starting the notebook it shut down after a few seconds.
                Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                The time until shutdown varies slightly.
                What I've tried so far:
                - cmos cleared
                - removed all components that are not essential for motherboard testing including keyboard and touchpad
                - ram exchanged
                - same behaviour with power supply or battery...
                07-21-2023, 01:04 PM
              • doejohn11
                Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                by doejohn11
                Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                04-19-2025, 07:38 AM
