ASUS A52JK fan at 100% speed
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Re: ASUS A52JK fan at 100% speed
    Originally posted by bios
    Hello ala borbe, Can you please share some idea oh how to repair a corrupted bios. do you use other software to edit the eeprom? I'm using TL866CS programmer. or anyone can give some idea so we can do our home work
    im interested too
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      well there is no magic there.. all done manually with hex editor
      i was going to make some kind of mini tool, since ive taken some C++ courses but i do not have time right now (working two jobs)
      anyway, i do it like this
      first you make full dump of bios (in this case 4mb, file named "A52JK Bios Dump.bin")
      then download official update from Asus website (2mb named "K52JKAS.208")
      open 2mb file in hex editor
      and select first 4 or 8 bytes depending on version change (image 1)
      open dump file and do hex search for selected bytes in dump (image 2)
      select all bytes from first file (ctrl+a) and paste over found bytes but be sure that found bytes and pasted bytes match adresses (image 3)
      new saved file must be same size like dump file
      save new file and flash with programmer
      this is like a mini tut, made in educational purposes... i use this to fix asus bios, but similar method can be used for many other vendors. also thre are cases where this does not apply
      Im Back... sort of...
      • dj_ricoh
        • 2073
        so let me get this.
        you just take the Online bios and compare it in hex editor with the original one from the notebook and if you see a line similar but corrupted you copy from the ONLINE and paste in to the original laptop bios?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          yes,
          keeping first part which contains data like ME region and LAN MAC address intact and specific for that unit only... there is somewhere data on fan speed, so that must remain intact.
          overwrite only main bios, which is obtain from web update, and also that is a part which get corrupted cos ezflash and bupdater only update that main part, does not touch nothing before it (i call it main cos there are data that actually initializes devices like cpu, chipset, vga, lan and then read that first part and set devices with data read from it)
          • bios
            • Nov 2014
            • 64
            • Philippines
            Thank you ala borbe for sharing your knowledge.
            • foxfaisal
              • Feb 2017
              • Malaysia
              #26
              Good day. Since you mention about processor upgrade, I would like to ask about the same thing related to my laptop.
              I own an ASUS A52JK that was bought in 2010. It comes with Intel® HM55 Express Chipset & Intel® Core™ i5 430M Processor. The specification for the laptop is available in the link below:
              https://www.asus.com/Notebooks/A52JK/specifications/
              Beside the Intel® Core™ i5 430M Processor, this laptop model also comes with different processors (according to the link above), which are:
              a - Intel® Core™ i5-540M Processor
              b - Intel® Core™ i5-520M Processor
              c - Intel® Core™ i5-460M Processor
              d - Intel® Core™ i5-450M Processor
              e - Intel® Core™ i3-370M Processor
              f - Intel® Core™ i3-350M Processor
              g - Intel® Core™ i3-330M Processor
              My laptop is still in good condition, however lately it feels slows whenever I'm running newer programs such as Ms Office 2013 & 2016. At first I decided to buy a newer laptop (an MSI GE62 6QD Apache Pro, an ASUS ROG GL552VW or an ASUS ROG G501VW. Before purchasing the new laptop, my friend of mine suggested me to upgrade the HDD in the laptop to SSD. After upgrading to SSD, another friend of mine suggested me to upgrade the CPU to i7 (provided that the socket is the same).
              According to ark.intel.com website, the processors that are compatible with Intel® HM55 Express Chipset are listed in the link below:
              http://ark.intel.com/products/43183#@compatibility
              Out of all the processors listed in the link above, I am interested with the following processors:
              a - Intel® Core™ i7-940XM Processor Extreme Edition (8M Cache, 2.13 GHz Base Frequency, 3.33 GHz Turbo Frequency, 4 Cores, 8 Threads, 55 W TDP)
              b - Intel® Core™ i7-640M Processor (4M Cache, 2.80 GHz Base Frequency, 3.46 GHz Turbo Frequency, 2 Cores, 4 Threads, 35 W TDP)
              I have 1 question - can I simply remove the existing Intel® Core™ i5 430M Processor and then replace it with either one of the 2 i7 processors above (Intel® Core™ i7-940XM Processor Extreme Edition OR Intel® Core™ i7-640M Processor)?
              If not possible, can I replace the existing Intel® Core™ i5 430M Processor with the fastest i5 processor that is compatible with Intel® HM55 Express Chipset? According to the http://ark.intel.com/products/43183#@compatibility link, the fastest compatible i5 processor is:
              a - a - Intel® Core™ i5-580M Processor (3M Cache, 2.66 GHz Base Frequency, 3.33 GHz Turbo Frequency, 2 Cores, 4 Threads, 35 W TDP)
              If still not possible, I think the only possible thing that I can do is to replace the existing Intel® Core™ i5 430M Processor with the fastest i5 processor that comes together with ASUS A52JK model. According to the https://www.asus.com/Notebooks/A52JK/specifications/ link, the fastest ASUS A52JK model is:
              a - Intel® Core™ i5-540M Processor (3M Cache, 2.53 GHz Base Frequency, 3.066 GHz Turbo Frequency, 2 Cores, 4 Threads, 35 W TDP)
              I hope I can get advice and guidance from all of you regarding this matter. Thank you very much.
              • Me.Orouji
                • Dec 2015
                • 117
                • Iran
                #27
                Thanks alot
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • abhorsen
                  Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                  by abhorsen
                  Hey guys,
                  Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                  Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                  Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                  07-06-2023, 10:22 AM
                • garretofriviaaaaa
                  ASUS GL702V Bios flash
                  by garretofriviaaaaa
                  Hello all, so basically I have a bricked GL702V with no power except a single LED flash on the power button when it is pressed. Customer had tried to flash his bios with a USB and the GL702VM310 version of this laptop's bios. I've been scouring the web for a correct version of his bios but all the ones on the ASUS website are for GL702VM, GL702VT, GL702VS, or GL702VI with versions varying from 300-310. This specific laptop has nothing other than just the GL702V so I don't know which bios is compatible with it. I was planning on programming it with the CH341A programmer as soon as I found the correct...
                  03-28-2024, 04:58 PM
