mac a1286 - 820.2850a not turning on
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: mac a1286 - 820.2850a not turning on
    managed to put it to turn on , reflowed a small bga that have this silicon around , right above the g3hot coil
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      ok fixed the machine , reballed the small bga , and its now working
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        well done, so smc reflow fixed it
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            but once agai nthk dellxps15 , as usual your tips take me to the place ,i must be to fix it .
            cheers mate
            • marcelofct
              macbook a1286 820-2915-b not turning on
              by marcelofct
              friends I need your help I have this macbook a1286 with the motherboard 820-2915-b but I can't fix it when I connect it to the power supply it turns on the green light and consumes 0.01x amp x= I don't have a 4-digit power supply, looking into schematic I do not have PP5V_S3 that comes out of ic u7201 I have the following
              PPBUS_G3H=12.59
              PP3V42_G3H= 3.48
              PPVRTC_G3H=3.48
              PP5V_S5=3.34
              PP5V_S3=0V
              ic u7201
              EN = 2.XV
              EN1= 0V
              EN2=2 3.3V
              PGOOD =0V
              please help
              attached boardview and schematic
              apparently...
              05-10-2022, 02:46 PM
            • Sparklingx
              HP 450 g1 keeps turning on even tho shutdown/sleep
              by Sparklingx
              HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
              09-23-2024, 12:34 AM
            • khelane
              Satellite PRO A50-A Not turning on after turning off Windows
              by khelane
              Hello
              A device with specifications
              Toshiba Satellite PRO A50-A is here to replace the hard drive.
              The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
              The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
              04-20-2023, 06:28 AM
            • Rabit
              VX3276-2K-mhd-2 Random Turning off
              by Rabit
              Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
              When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
              This can be signs of bad capacitors causing overheating PSU ?
              06-17-2024, 09:30 AM
            • platinumsteel
              Macbook Pro A1286 820-2915 GreenLight 200 Milliamps Not Turning On
              by platinumsteel
              Hi guys hoping you all can save a life here.Because i think i messed up.The history of this machine is that it was working and functioning perfectly.Well as you know these are one of the machine models with the dedicated GPU that is faulty.So i made an attempt to try the dosdude method of ''Permanently Disabling the 2011 MacBook Pro 15" Dedicated GPU'' using the Lattice USB Programmer and well i don't know what went wrong I followed the video to a T but after soldering the wires on the pads just like the video instructions i realized that the Macbook Pro no longer turns on.It just gives me...
              12-21-2020, 07:00 AM
