Macbook pro A1278 no power with led green on magsafe
  • opethfan
    • Feb 2015
    • 81
    • Italia
    Hi!
    this is my first macbook and i'm trying to repair it.
    I have read many posts but they can't solve my problem.
    on the mainboard there isn't any burnt component and the main fuse is ok.
    in the picture you can see my first measures near the main connector.
    Hope someone helps me
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Macbook pro A1278 no power with led green on magsafe
    post picture of the other side.
    and post voltage on the 2 spot ive marked.
    • opethfan
      • Feb 2015
      • 81
      • Italia
      thanks for your reply
      • opethfan
        • Feb 2015
        • 81
        • Italia
        here others measurement
        • opethfan
          • Feb 2015
          • 81
          • Italia
          here others
          • dellxps15
            • Feb 2014
            • 1591
            • italy
            making measure all around the board without a logic is no sense. this big thing with all 0 volt is lan filter..... useless to measure for now.
            i asked for 2 measure on these 2 coils (inductor) in my previous post.
            next report voltage on green zone.
            total 2 measure+ 1 ground.
            u should have on green spot (white fuse) 12.5 volt ;
            3.42 on the other green marked area.
            if u have 3.3 volt on coil, u have 12.5 volt on that green marked fuse, and if u have 3.35 or higher (not over 3.42) u can put a fan, some ram slot, lvds connector with lcd and short that circled 2 dot on mainboard with a wtezer (smc bypass) and see if macbook start normally.
            before all that, make sure u understand that procedure right. shorting those 2 pins should make your macbook start, so put fan, ram ecc ecc and be carefull to not short anything else. put all component on a non conductive zone.
            u can try with magsafe only,with battery only , and with both.
            any throuble, ask before act.
            • opethfan
              • Feb 2015
              • 81
              • Italia
              in the green marked zone i have 12.5, the same voltage on the near white fuse
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                there are 2 green marked zone.. one left (white fuse) one circled green with short write. post voltage on those 2 pads. one is ground so no voltage, but the other should have voltage around 3.42volt.
                • opethfan
                  • Feb 2015
                  • 81
                  • Italia
                  ok
                  • dellxps15
                    • Feb 2014
                    • 1591
                    • italy
                    follow procedure of smc bypass by shorting green circled mark (3.45volt and gnd) with ram and fan connected and report if macbook start.
                    • opethfan
                      • Feb 2015
                      • 81
                      • Italia
                      it doesn't start...
                      • dellxps15
                        • Feb 2014
                        • 1591
                        • italy
                        report voltage in marked green coil (inductor)
                        suspect u misisng 3.3 volt as bios doesnt have 3.3 volt.
                        • opethfan
                          • Feb 2015
                          • 81
                          • Italia
                          there are 3.3 volts on that coil
                          • dellxps15
                            • Feb 2014
                            • 1591
                            • italy
                            down the arrow there is bios chip. post voltage.
                            (the other one in first picture was lan chip)
                            • opethfan
                              • Feb 2015
                              • 81
                              • Italia
                              0 volts on every pin of bios chip
                              • dellxps15
                                • Feb 2014
                                • 1591
                                • italy
                                voltage on these 2 component and those 2 resistors ?
                                all marked with circle green
                                • opethfan
                                  • Feb 2015
                                  • 81
                                  • Italia
                                  ok
                                  • dellxps15
                                    • Feb 2014
                                    • 1591
                                    • italy
                                    someone already put hands on this board i think
                                    missing component marked with green circle.
                                    code: u7740
                                    component: TPS720105
                                    • opethfan
                                      • Feb 2015
                                      • 81
                                      • Italia
                                      as you can see in this picture, that chip in not present on the same motherboard...
                                      • dellxps15
                                        • Feb 2014
                                        • 1591
                                        • italy
                                        on my schematic it was not mentioned "no staff" .... weird apple
                                        report voltage on that chip.
                                        also in the near resistor.
                                        also normal and while shorting the 2 spot i mentioned before (3.45 and gnd)
