Acer 7736z no power on, can't figure it out
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Schematic here.
    I have this laptop which does not power on, nothing happens when i press the power button I have 3.3v and 5v standby, i am getting power to the KBC and BIOS, and the power button has 3.3v also. The button is good. I have not found any shorted parts, have checked all main rails.
    What i have noticed is that 3.3v and 5v main do not come up. S5_ENABLE going from KBC to U62 ISL62392 is at 0.39v and goes to 0v when the power button is pressed. I think it should be the other way round and it should go to 3.3v but it does not.
    Things i have tried: Flashing BIOS. Same behavior.
    Forcing enable to 3.3v standby. 3.3v standby drops to 2.2v or something, although i do not have high current (it's under 1mA) and the main power supply still does not power on.
    Replaced U62 with a new one. Same thing.
    Replaced KBC. Still the same.
    Measuring without power, S5_enable is not shorted so i do not understand why it does not go to 3.3v. I've run out of ideas on this one. Any help is welcome.
    A working TV? How boring!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: Acer 7736z no power on, can't figure it out
    resistors around s5_enable/p.42/ signal have right resistance? diode D13 is ok?
    • khaahk
      • Dec 2013
      • 756
      • Estonia
      The word out there is that U58 gets shorted...
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        All mosfets have been tested ok, no shorts. I'll try checking the resistors and diode D13 although i doubt i will find anything interesting.
        • atsio
          • Oct 2013
          • 819
          • Greece
          Remove L27 and L28, supply current and check if anything draws current and what is getting hot. Main suspect is shorted vga.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            This has onboard video. But i will try that before i put the thing back together and send it back.
            This is from work (i made the mistake of going back to work) and my boss said the guy who brought it in keeps calling twice every day and he's already pissed off about that, so he'd rather have us give it back still broken, than being bothered continuously by phonecalls. I can understand that. It's happened before at the shop and it's annoying indeed. However, it's funny how this never happened with any of *my* customers.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Removed coils and applied 3.3 and 5v from PC PSU, nothing getting hot and current consumption is low. I'm not bothering with this one anymore.
              • whaldsz
                • Apr 2013
                • 395
                • Philippines
                How about checking if ECRST# is 3.3v?
                • zedameo
                  • Jan 2019
                  • 14
                  • algeria
                  thank you . it was it (U58)
                  • Destroyer-Br
                    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                    by Destroyer-Br
                    I'm working on an Acer Nitro 5 unit with the following specs:
                    • Motherboard: LA-J871P Rev: 1B
                    • Model: Acer AN515-55-59MT
                    • S/N: NHQ7JAL00403906A973400
                    • SNID: 03902728734
                    Initial Issue
                    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                    04-17-2025, 08:18 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Victor Moreira Silva
                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                    by Victor Moreira Silva
                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                    Well, my decice specs are the following:
                    Model: Acer Nitro 5 AN517-54-55T5
                    CPU: Intel Core i5-11400H
                    GPU: NVIDIA GeForce GTX 1650
                    Motherboard: GH51G LA-L181P Rev:1c
                    The symptom:
                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                    05-26-2025, 10:49 AM
                  • Bonaventure Vigil
                    ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                    by Bonaventure Vigil
                    Dear All,
                    Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                    At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                    12-12-2024, 10:22 AM
                  • justice171
                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                    by justice171
                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                    1. Verified that all critical voltages are present:
                      • 3.3V and 5V are always present if DC is plugged.
                      • 1.8V on the BIOS chip is present.
                    2. Checked the power button functionality:
                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                      • Confirmed connectivity is intact, ruling out issues
                    11-26-2024, 12:39 AM
