HP CQ61 - not working : please help
  • Bucki82
    • Jan 2015
    • 6
    • England
    Hi
    Hope I can ask question about this laptop too?
    I got this HP PRESARIO CQ61 and it wont power up, no noise no nothing.
    Only the power jack light stays on, when plugged it (wont run on battery either) No other lights are present.
    I taken it apart and kind of trying to find out where the power is stooping
    I am not an electronic engineer but willing to go the extra mile and try to learn out of this, maybe someone be willing to help ... ??
    I found this diagram
    but not sure if it is the right one ??? the laptop is an AMD processor.
    I checked the power at CN3 slot and the voltage correct:
    2 red cables get 19.47V
    checked the PC20 the tiny capacitors (i believe it is) and it gets 19.47V
    checked the PC14 and it gets 19.47V
    checked PD1 and PR6 and both get 19.47V
    also checked C24 and there I get 0.01V on either side.
    so, not sure where else to check ... or why that capacitor is not working.
    I flipped the motherboard to the other side, a just about the same area
    where I was taken the previous measurement, there are 2 MOS FETS (i think) close to the RAM slots. so I checked the followings:
    PQ45 - 85U03GH
    Drain to Source (beeping sound) and goes from 233 down to 0.01
    Drain to Gate (no sound) stays 1
    PD17 - PS996 SD840S
    Pin3 to Pin2 shows 182 (in VOLTS shows 0.23)
    whereas Pin2 to Pin3 (beeping noise) and shows -147 (in Volts it shows -0.20)
    Pin 1 to Pin 3 = 0.01V
    Pin3 to Pin1 = 0.01V
    Please advise further .... and sorry about this, I am new to all this
  • inspirim
    • May 2013
    • 286
    • Italy
    Re: HP CQ61 - not working : please help
    check the supply voltage of integrated BIOS pin 8 must be 3.3 volts
    • Bucki82
      • Jan 2015
      • 6
      • England
      BIOS pins:
      8th pin shows 3.39V
      5th pin shows 0.24V
      4th pin shows 0.01V
      1st pin shows 0.18V
      Regards the mosfets, I mentioned above... just checked the DRAIN (right side pin) and one of them shows 19.29V and the other one shows 19.50V
      so, they seem to work fine then, as previously thought not working!
      Any further suggestions?
      • Bucki82
        • Jan 2015
        • 6
        • England
        Help please????
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • flusher
          A2485 MBP16 M1 820-02100 not charging
          by flusher
          Bought myself a project. Waterdamage to the left wing. Front side got damage on top up to SSD area. Back - near CD3218 both CD3217. Had to replace a lot of caps and resistors to make it perfect. No shorts. Didnt lift any chips yet but microscope shows good balls from sides. Anyway. It powers up and boots fine.
          Right single usbc shows 20v on meter 0 amp
          Left upper usbc shows 5v 0 amp
          Left bottom usbc shows 20v 0 amp
          magsafe shows orange but also does not charge
          nothing produces beep from mac when on
          when off - single usbc and magsafe produce beep but no beep...
          08-27-2025, 08:25 PM
        • Rezendes
          820-3115-B No Orange Light, Won’t charge battery
          by Rezendes
          Hello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
          06-23-2024, 12:56 PM
        • gutkin
          HP 250 G8 Compal FPW50 LA-H325P
          by gutkin
          Hi colleagues.
          Here I am asking for help.
          I've entered this HP and it won't turn on. I can't find a schematic or boardview.
          The first fault I found was a JW5069a IC (compatible with JW5068a). It had an internal fault, which was replaced, and now I have a stable 19V. When I press the power button, the LED appears, but it still consumes 500mAH.
          I continued taking measurements and found that the PUG8 IC is not receiving an EN on pin 2.
          PUG8:
          Pin 1 5V
          Pin 2 0V
          Pin 3 1.8V
          Pin 8 5V
          Pin 12 5V
          Pin 13 19V
          Pin 2 of...
          07-29-2025, 03:27 PM
