HP CQ61 - not working : please help
  • Bucki82
    • Jan 2015
    • 6
    • England
    Hi
    Hope I can ask question about this laptop too?
    I got this HP PRESARIO CQ61 and it wont power up, no noise no nothing.
    Only the power jack light stays on, when plugged it (wont run on battery either) No other lights are present.
    I taken it apart and kind of trying to find out where the power is stooping
    I am not an electronic engineer but willing to go the extra mile and try to learn out of this, maybe someone be willing to help ... ??
    I found this diagram
    but not sure if it is the right one ??? the laptop is an AMD processor.
    I checked the power at CN3 slot and the voltage correct:
    2 red cables get 19.47V
    checked the PC20 the tiny capacitors (i believe it is) and it gets 19.47V
    checked the PC14 and it gets 19.47V
    checked PD1 and PR6 and both get 19.47V
    also checked C24 and there I get 0.01V on either side.
    so, not sure where else to check ... or why that capacitor is not working.
    I flipped the motherboard to the other side, a just about the same area
    where I was taken the previous measurement, there are 2 MOS FETS (i think) close to the RAM slots. so I checked the followings:
    PQ45 - 85U03GH
    Drain to Source (beeping sound) and goes from 233 down to 0.01
    Drain to Gate (no sound) stays 1
    PD17 - PS996 SD840S
    Pin3 to Pin2 shows 182 (in VOLTS shows 0.23)
    whereas Pin2 to Pin3 (beeping noise) and shows -147 (in Volts it shows -0.20)
    Pin 1 to Pin 3 = 0.01V
    Pin3 to Pin1 = 0.01V
    Please advise further .... and sorry about this, I am new to all this
  • inspirim
    • May 2013
    • 282
    • Italy
    Re: HP CQ61 - not working : please help
    check the supply voltage of integrated BIOS pin 8 must be 3.3 volts
    • Bucki82
      • Jan 2015
      • 6
      • England
      BIOS pins:
      8th pin shows 3.39V
      5th pin shows 0.24V
      4th pin shows 0.01V
      1st pin shows 0.18V
      Regards the mosfets, I mentioned above... just checked the DRAIN (right side pin) and one of them shows 19.29V and the other one shows 19.50V
      so, they seem to work fine then, as previously thought not working!
      Any further suggestions?
      • Bucki82
        • Jan 2015
        • 6
        • England
        Help please????
