HP 250 G8 Compal FPW50 LA-H325P
  • gutkin
    SIR
    • Nov 2016
    • 19
    • argentina
    Hi colleagues.
    Here I am asking for help.
    I've entered this HP and it won't turn on. I can't find a schematic or boardview.
    The first fault I found was a JW5069a IC (compatible with JW5068a). It had an internal fault, which was replaced, and now I have a stable 19V. When I press the power button, the LED appears, but it still consumes 500mAH.
    I continued taking measurements and found that the PUG8 IC is not receiving an EN on pin 2.
    PUG8:
    Pin 1 5V
    Pin 2 0V
    Pin 3 1.8V
    Pin 8 5V
    Pin 12 5V
    Pin 13 19V
    Pin 2 of the PUG8 shows continuity with pin 72 of the KCB ENE KB9022Q D. Where I also have 0V.
    Checking the PLG13 coil. When a voltage drop occurs, it measures a short. I checked the PQG13 mosfet off the board; it shows no faults, but the board shows continuity between Source and Drain (without the mosfet connected).
    When I lift any pin on the coil, it no longer shows continuity.
    As a reference measurement, the PLG13 coil should have a voltage of 0.70 or 0.72V (reference voltage of a device with the same board in operation).
    I've attached some reference images.
    I'm leaving a reference to the KBC. I understand you can take some measurements with the PDF I'm leaving.
    If you need higher-quality images, I can upload them.​
  • mon2
    • Dec 2019
    • 14720
    Which part is PUG8? Is it the 3H=8H regulator?
    This is Richtek RT6585BGQW
    https://www.richtek.com/assets/produ...85AB_DS-07.pdf
    • gutkin
      SIR
      • Nov 2016
      • 19
      • argentina
      Yes, I've been investigating, but this IC, as you indicate, 3H=8H, has 28 pins. 7 on each side, it's more similar to RT3601EAGQW
      https://www.alldatasheet.es/datashee...3601EAGQW.html
      What do you think?
      I'm worried about the pqg13 that shows continuity between drain and source. I understand that's why I don't have the EN on the IC.
      • Rauni
        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
        by Rauni
        Hello, this is my first post on this forum, and my first attempted to repair a TV.
        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
        Read also that we should test what happens if we...
        10-01-2023, 12:06 AM
      • Stanley1843
        Dell Inspiron 15 3520 - AC Adapter shows "Not Installed - Not Charging
        by Stanley1843
        I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?...
        09-27-2025, 08:44 PM
      • GeeksOnCall580
        Dell-Alienware-X15-R2-Compal-HDS70-LA-L613P-Rev-1
        by GeeksOnCall580
        ALSO FOR THE X17 VER:1.0 AND 2.0 SCHEMATIC! FOR ALL OF YOU GUYS!...
        08-30-2025, 08:21 PM
      • speaktorob
        Reference Nvidia GTX 980 ti - looking for a new shroud
        by speaktorob
        So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
        Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
        03-22-2024, 03:00 AM
      • rumpumpel1
        ThinkPad T470s dead
        by rumpumpel1
        Hello guys, I have a ThinkPad T470s that no longer starts (black display). As a reference, I have another T470s board that works normally. The defective board (with fan and display only) shows power consumption as shown in the linked image . The lower chart shows the defective board (it stays at 500mA forever), the upper chart shows the reference board. x-axis shows seconds. The heat sink also gets warm. From all this, I conclude that the CPU is operating.
        The fuses are all fine and a visual inspection of the board showed nothing unusual.
        I also checked all the voltage rails and...
        03-29-2023, 08:58 AM
