Dell N5050 Not Power ON, but the RSMRST# 0.50v . Please reply.
Re: Dell N5050 Not Power ON
trying to do that more easily by replacing the IC bios first and reprogrammed. then if it does not work, you might have to replace the chip sioComment
Dell N5050 WISTRON EnricoCaruso 15 UMA DV15 RX01 10316-1 HR 0602, right?
I am a newbie as well.
when a voltage is 19v, 3.3v and 5v already available, try measuring the voltage U2701 pin 97,64,21,17,14 & 4
don't forget, be carefully! slip your probe, you got more troubleComment
have you ever tried to turn without cpu and ram?
please try measuring the resistance all big coil to ground, without power and battery, cpu and ram previously separatedComment
Assuming...7 Photos -
by Mark01Hi guys,
This is my first post! 🚀
I have no idea what I’m doing, but I’m learning by trial and error.
I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by seppdeHello everyone,
I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short... -
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM - Loading...
