Dell N5050 Not Power ON
  • shijeesh
    • Mar 2011
    • 65
    Dell N5050 Not Power ON, but the RSMRST# 0.50v . Please reply.
  • shijeesh
    • Mar 2011
    • 65
    Re: Dell N5050 Not Power ON
    Please help.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      as always, check main 3.3V and 5V
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        yes right
        you must have 19V, 3.3V and 5V. as main power
        • dj_ricoh
          • 2073
          • uk
          Originally posted by shijeesh
          RSMRST# 0.50v
          RSMRST comes after 3.3VALW and 5VALW comes
          • shijeesh
            • Mar 2011
            • 65
            19V, 3.3V and 5V. as main power voltages are ok .Power switch 3.3v is also available.
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              in my opinion, if rsmrst # 0v means bios and sio chips problematic.
              trying to do that more easily by replacing the IC bios first and reprogrammed. then if it does not work, you might have to replace the chip sio
              • shijeesh
                • Mar 2011
                • 65
                I changed EC ic (NPCE795PA0DX-GP-U) and replaced bios with working one. The rsmrst# exactly 0.5v only.
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  Dell N5050 WISTRON EnricoCaruso 15 UMA DV15 RX01 10316-1 HR 0602, right?
                  I am a newbie as well.
                  when a voltage is 19v, 3.3v and 5v already available, try measuring the voltage U2701 pin 97,64,21,17,14 & 4
                  don't forget, be carefully! slip your probe, you got more trouble
                  • shijeesh
                    • Mar 2011
                    • 65
                    I measured that voltage U2701
                    Pin 97 --- 110mV (AD_IA)
                    Pin 64 --- 0V (PM_SLP_S3#)
                    Pin 21 --- 0V (PM_SLP_S4#)
                    Pin 17 --- 3.3V (LID_CLOSE#)
                    Pin 14 --- 3.3V (S5_Enable)
                    Pin 4 --- 0.50V (VDD 3D3V_S0)
                    These are the voltages.
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      have you ever tried to turn without cpu and ram?
                      please try measuring the resistance all big coil to ground, without power and battery, cpu and ram previously separated
                      • noobdeal
                        • Mar 2015
                        • Philippines
                        please link me to the diagram..im newbie here need help pls i have the same problem.
                        • shijeesh
                          • Mar 2011
                          • 65
                          https://www.badcaps.net/forum/showth...ighlight=n5050
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Mark01
                            Dell Optiplex 7490 AIO - red power led after flash
                            by Mark01
                            Hi guys,
                            This is my first post! 🚀
                            I have no idea what I’m doing, but I’m learning by trial and error.
                            I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                            07-04-2025, 12:54 PM
                          • zlr8r
                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                            by zlr8r
                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                            Ill try and give as much info as I can.
                            Dell Inspiron 17 (7786) Laptop
                            Service Tag: 5J0NHT2
                            Bios: 1.9.0
                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                            Then it started getting weirder!
                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                            12-12-2023, 09:31 PM
                          • LimesKey
                            Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                            by LimesKey
                            Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                            10-17-2025, 05:33 PM
                          • seppde
                            Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                            by seppde
                            I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                            My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                            Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                            Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                            10-01-2024, 10:57 AM
