Clean bga with ultrasonic
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Hi all, I read that in some cases to clear bga with a non ultra expensive (permit to change the frequency ) ultrasonic wash can damage the chip.
    Some experience....
    thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Clean bga with ultrasonic
    i clean hundreds mobile phone boards with ultrasonic bath with no damage.
    every good technician doing this after liquid damage.
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      I use the same method with no problem, but I assume that the article I read, referred about an issue of separation between the die and the golden thread. It's possible?
      How liquid you use ? I try some liquid and various temperature but I have the best result , especially to remove the flux after a reballing, with a isopropil alcool at 60-70 C° or for particular cases an ersa solvent. with distilled water, the results are poor as well as with specific liquids, probably for the frequency, my bath operates at 44 Khz but I read of devices operating at much higher frequencies.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        i dont using utrasonic bath after reball. only for removing oxidation after liquid damage under the bga.
        • diif
          • Feb 2014
          • 6978
          • England
          The only damage i have read about is if the chip touches the inside of the bath, which can cause physical damage to the chip and also the bath. The chip/item should be in a try or suspended.
          I use IPA in my bath but i don't clean BGA chips in mine.
          • Ramee
            • Jul 2014
            • 218
            • Israel
            Agreed to diif. They are not ESD safe.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              ofcourse thats why all using some kind of nonmetal "carpet" on bottom of ultrasonicbath
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                I find the article, can I post the full link ?
                http://www.xxxxxxx.org/mart/50226F.shtml
                • trebo
                  • 514
                  • Wales, UK
                  all I get is this,
                  (Controller file /home/orgclini/public_html/xxxxxxx.org/libs/controller/mart.php not found.)
                  Is it just me again
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    maybe he meant this link
                    http://www.ipcoutlook.org/mart/50226F.shtml
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      I am a newbie to this forum and not know the policy to post a link.
                      the right link is http://www.ipcoutlook.org/mart/50226F.shtml
                      • Bobdee
                        • Jun 2008
                        • 461
                        thanks
                        Cheers jasko
                        • reaper57
                          • Sep 2014
                          • 216
                          • Norway
                          An ulrasonic bath shouldn't damage the bga. I've done not only phones, but also CPUs, tablets, laptop motherboards and other PCBs. The weirdest thing that I have fixed with an ultrasonic bath was an iPad camera. Isopropyl alcohol didn't work, but after the bath it worked like new.
                          Keyboard not detected, press F1 to continue...
                          • Joseph cauchi
                            jccomputers
                            • Jan 2015
                            • 89
                            • Malta
                            Can somebodt tell me what liquid mix to use in ultrasonic for mobile and BGA
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              I did not know an ultrasonic cleaner is not ESD safe - i removed the plastic tray from mine when i got it, and forgot where i've put it. I've cleaned lots of BGAs in it and it didn't damage any of them. But i always put the BGAs in with the pads facing up.
                              A working TV? How boring!
                              • rounin
                                MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                                by rounin
                                Device Information
                                • Model: MacBook Pro 14” M1 Pro (A2442)
                                • Logic board number: 820-02443-05
                                Original Issue
                                The device suffered liquid damage, causing a short circuit on the logic board.
                                Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                                Work Performed
                                Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                                Current Status
                                • When powered on, the screen shows support.apple.com/mac/restore....
                                10-20-2025, 11:15 PM
                              • mon2
                                A1466 Macbook Air (Liquid damage repair)
                                by mon2
                                Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                Macbook AIR Model A1466 Diagnostic 09-01-2021
                                Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                Problems & Resolutions
                                1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                09-01-2021, 09:31 AM
                              • rilley
                                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                by rilley
                                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                And the resistor L4004 is literally burned.
                                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                07-10-2024, 01:57 AM
                              • Jenzo
                                MacBook A1989 overheating after liquid damage
                                by Jenzo
                                Hey everyone,
                                Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                                I can't figure out how...
                                05-13-2023, 07:58 AM
                              • mitchw
                                MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                by mitchw
                                Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                I quickly took it apart and washed the liquid residue off the mainboard.
                                The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                Now the laptop...
                                07-16-2025, 07:55 AM
