HP 8460p no backlight
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    HP 8460p turns on and seems to function as normal with the lack of any backlight. I would assume this is an inverter issue, but there is no inverter daughter board that I see in in the teardown videos, and I don't know how to troubleshoot pins/voltage coming off the MB. Can anyone help me with that? Or is the inverter built into the screen on these?
    Is this a screen issue or a motherboard issue?
    Cheers,
    Alex
  • withalligators
    • Jun 2013
    • 267
    Re: HP 8460p no backlight
    Ok, I tried a new screen, since it looked like the screen may have had an inverter built onto it, but still no luck. Any idea?
    • khaahk
      • Dec 2013
      • 759
      • Estonia
      Start from lvds connector.
      How did the problem start?
      • tata123
        • Nov 2013
        • 104
        check near the LCD connector the fuse!!
        • sunilnjarakkat
          • Dec 2013
          • 13
          • u.a.e
          Led cable problem
          • withalligators
            • Jun 2013
            • 267
            Welp, I finally got some time to fiddle with this, and there's a big ol burned up something on the other side of the MB from where the LVDS plug is. Looks like a mobo swap is in order.
            Thanks for the help guys,
            Alex
            • dj_ricoh
              • 2073
              Alex
              what voltage do you got on the screen connector?
              bypass it and that`s it "full brightness" and your on
              i`m :O that it still works; clean it and check the voltage on the connector ! you can wire all the voltage and done!
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                In this situation I prefer to compare the burned part with the same part of a good motherboard to rebuild the pads and route with copper and epoxy.
                • withalligators
                  • Jun 2013
                  • 267
                  That does sound interesting and I've never done it before. Unfortunately, a bunch of the little caps fell off the burned area. I scraped around in it, and the burn goes almost halfway through the board. I'll look at what's on there when I get the new board and see if it's worth replicating.
                  Cheers guys
                  Alex
                  • trepachka
                    HP Probook 450 G8 Boardview+Schematics - screen backlight issue
                    by trepachka
                    I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
                    Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
                    Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
                    03-16-2024, 12:32 AM
                  • ScHAmPi
                    Samsung UE48JU7000 screen issue after backlight replacement
                    by ScHAmPi
                    Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                    I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                    07-15-2024, 05:41 AM
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
                  • Cornito
                    Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                    by Cornito
                    Hello Team,
                    I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                    Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                    Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                    08-08-2024, 08:09 AM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
