asus x53e weird issue.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hi guys, need your help....
    i got here asus x53e thats turn on for a couple of sec then off. sometimes its look like restarting over and over that you can notice the power on led on and off again and again. and good thing is its display for sometime for a munite then again off. its kind of weirdo... hope anybody could help.
    tnx
    heres what i did.
    i just clean mobo. replace thermal paste on cpu
    i did mild reflow on the gpu.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: asus x53e weird issue.
    look for voltages on all big coils.
    • rickybucalan
      • May 2013
      • 322
      • philippines
      i got the 3.3 and 5v supply before it turn on.
      i can't get those voltage bcoz of it turn off quickly. but one time it takes a bit long stay on so i got those voltage it has 1.5v and 1.0 v some of them.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        u need to check all woltages on coils right after start. check for rising voltage. if no rising, than there must be short
        but i think u need to reflow od northbridge
        • rickybucalan
          • May 2013
          • 322
          • philippines
          here i attached some picture. i did a reflow but it do the same. i been using it for 3days working fine but then it happen again this morning. its a bit crazy.
          • rickybucalan
            • May 2013
            • 322
            • philippines
            i did windows bios update. but it does the same. any thought guys.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              reflow nb
              • Ramee
                • Jul 2014
                • 218
                • Israel
                On the picture i still can see the wlan card still connected to the board, remove that and try to fire it up.
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  hi guys. now my laptop doesn't work again. but now it goes on and off again and again without display. what do you think the problem? would u think its SIO Chip issue?
                  • dj_ricoh
                    • 2073
                    take the bios bat out and discharge the board!(i mean let the battery out)
                    why do i think it will power up by it self?!?!?
                    • rickybucalan
                      • May 2013
                      • 322
                      • philippines
                      i really have mo idea. as soon i plug the charger it goes on and off the light.
                      • lukkihapsi
                        Asus Vivobook X515JA Weird Boot Issue
                        by lukkihapsi
                        Asus Vivobook X515JA Laptop
                        Issue :
                        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                        Tried :
                        Cleaned inside for dust, applied fresh thermal paste. No Change!
                        Removed keyboard, Trackpad, fingerprint sensor. No Change!
                        Removed Internal SSD. No Change!
                        Updated BIOS to latest version. No Change!
                        Removed battery and pressing power button for 1 minute. No Change!
                        Weird Part :
                        Upon turning laptop ON, screen lights up - stays black,
                        I...
                        07-07-2025, 12:07 PM
                      • bajdik
                        Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                        by bajdik
                        I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                        Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                        I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                        Unfortunately, I don’t have access to the schematic.
                        It seems to me that when I bend the board, something changes.
                        Could this...
                        08-13-2025, 07:26 AM
                      • MakNCheese
                        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                        by MakNCheese
                        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                        Symptoms:
                        • Severe lag across the system, including BIOS navigation.
                        • Slow boot times and unresponsive performance in Windows.
                        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                        • No error messages or BSODs, just extreme sluggishness.
                        What I've Tried:
                        • Replaced
                        06-04-2025, 12:48 AM
                      • ZixuTech
                        Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
                        by ZixuTech
                        Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
                        Perhaps BIOS issue?
                        Brand: Asus
                        Model: F1502Z
                        SN: R4N0CV11S622169
                        Board: X1403ZA 2.2
                        I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
                        Can you clean and enter SN for me please....
                        03-31-2025, 05:04 PM
                      • SuperJames
                        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                        by SuperJames
                        This one's a weird one, and still unsolved despite it having gone back to Dell once.
                        Specs
                        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                        Backstory
                        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                        10-23-2023, 04:09 PM
