asus x55A no power
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: asus x55A no power
    Originally posted by ktmmotocross
    Hello.
    Have this asus X55A and i have 19V before the first power mosfet and 0.89V after the mosfet.
    i cannot find schematic so any help would be needed
    Can this help? I hope the A and the S don't make that much difference.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      maybe u forgot to attach something
      • atsio
        • Oct 2013
        • 819
        • Greece
        Hello.
        If you have 0,89 volt usually it is not a problem of BQ25. It's a problematic fet.
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          I thought I had found a good one but that was posted earlier already.
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            found something, you never know until you try.
            • toske666
              • Feb 2016
              • Serbia
              #26
              Greetings to the forum,I have a problem with my laptop Asusx55a?The problem is laptop does work in the charger,only work on battery,and when the battery is charged with the other laptop, when i put in my laptop and turn on the laptop,discharges battery and should be to recharging the battery ?means works until the battery in use,when is empty battery laptop not working or want to charge???? Please Help Meeeeee :-) Regards
              • katzbo035
                • May 2016
                • Serbia
                #27
                Problem is solved. You have bad "mosfet" on matherboar behind the DC input. Replace the bad mosfet and that's it. On the video is a burning mosfet, bad you have a bad mosfet.
                https://www.youtube.com/watch?v=rwIq6ZnHIR4
                • akarta
                  • Nov 2015
                  • 16
                  • United Kingdom
                  #28
                  Asus X55A No power, No leds, Wont charge. Checked 5V and 3V (3V can be measured at Bios chip if you have no schematics) all voltage present. Checked CMOS battery: BOOM 0.3v. Replaced battery and laptop now works. Always check simple things first folks!
                  • DeniS182
                    • Jun 2014
                    • 328
                    • Slovakia
                    #29
                    I have problem with this laptop, have someone schematic?
                    I changed charger ic, two mosfets, and I haven't voltage on first mosfet Gate.
                    Only power led blinks.
                    MB is: X55A rev 2.2
                    • risting
                      • Jun 2015
                      • 32
                      • macedonia
                      #30
                      Re: AsUS x55A no power fix
                      i replace mosfet A5 GNC 100M01 with M0930M
                      and laptop again working but automatic go to bios no booting windows restart i will try to format and install new windows or motherboard again have some problem on board one mosfet CDJ0961 near to processor give me short to ground i don't know it is this correct inductor and smd capcitors on multimeter give me shorted beep
                      • risting
                        • Jun 2015
                        • 32
                        • macedonia
                        #31
                        video link here; https://www.youtube.com/watch?v=UeEzg2hw8ZM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • Thomas Smith
                          Asus Tuf gaming fx506l no power, mosfet does not open
                          by Thomas Smith
                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                          Initial Symptoms:
                          • The laptop has no power at all (no LEDs, no fan spin).
                          • No 3.3V or 5V present on the board.
                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                          Power Rail Checks:
                          1. Charger input (FETs PKCH2BB)
                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                          2. BQ24780S Charger IC:
                            • VCC and ACDET are present.
                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                            • Shunt resistor has 10Ω to ground.
                          03-30-2025, 03:38 AM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • ShadowAi
                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                          by ShadowAi
                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                          03-15-2024, 10:46 AM
