MacBook A1278 can't power on
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, been with this MacBook for a few months already, the issue lies on R5087: SMC_BC_ACOK (0.9V, should be 3.4V) - PP3V42_G3H (3.4V, this is good).
    What I do is I replace the R5087 resistor (470k), use it for 30 minutes, then the magsafe light goes off and in a few minutes it will shutdown.
    I've replaced U6900, U6901 and U7000 (charger IC) multiple times. R6929 is fine (2k ohms).
    The problem lies on the SMC_BC_ACOK line. I really need help on this one.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: MacBook A1278 can't power on
    did u try another magsafe and another power supply?
    • orientalsniper
      • Apr 2013
      • 461
      Yes, sadly I've tried another power adapter and it happens the same (power going out in 20-30 mins).
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        did u try reset smc ?
        maybe you are looking on the bad section. pc power off both battery only and dc only ?
        if it power off only with dc, then check u7000 pin voltage.
        • orientalsniper
          • Apr 2013
          • 461
          SMC Reset already done, power goes off even with battery plugged.
          Macbook can only power-on if the pullup resistor (R5087) has 3.4V in both sides. When the SMC_BC_ACOK side of that resistor (R5087) has 0.9V, MacBook fails to power-on.
          Now, SMC_BC_ACOK is CHGR_ACOK.
          And CHGR_ACOK comes from PIN14 of U7000 (charger IC), I suspect something is affecting this IC, since PIN14 is also 0.9V, but how??? I've already changed twice this IC.
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            dont really know well how u7000 works. it has many voltage like 5volt, 3.4 volt, 16volt, 12.5 volt. on macforum some dude should be able to help you. but if pin14 of u7000 is low, something with u7000 should be bad.
            or maybe something is bad with macbook pgood and smc send signal to shut down pc.
            ps: when pc shut down, magsafe light is green ?
            edit: on macforum searching google for "u7000 pin14 low" a good dude say that it could be a possible bad joint of that qfn. try to squize the solder iron on that side with a good flux and see if it goes ok.
            look: http://forums.macrumors.com/showpost...postcount=1848
            and specially look http://forums.macrumors.com/showpost...postcount=1867
            • orientalsniper
              • Apr 2013
              • 461
              That's interesting, I'm sure U7000 is fine since I've changed it twice and I've checked the solder points with magnifying lens.
              What I'm going to check are those resistors mentioned.
              Thanks for the assistance.
              EDIT: Yeah, magsafe light goes off before it shutdown (like 5-10 mins before).
              • ictc
                • May 2015
                • 46
                • Italy
                I had an identical issue coused by the bad solder joint on pad 14 of the qfn Q7000. Apparently the solder need to stick not just to the bottom side pads of the chip to make a proper contact...
                • Adogabriel100
                  Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                  by Adogabriel100
                  Hey! This is a A1278 macbook 2011.
                  Problem: Not turning on / No green light
                  Im using by3200s charger.
                  Voltajes:
                  PPBUS_G3H = 12.26v
                  SMC_RESET_L = 3.3v
                  PP3V42_G3H = 3.42v
                  U7000 =
                  Pin 1 CHGR_AGATE = 0v
                  Pin 2 CHRG_DCIN = 19v
                  Pin 3 CHRG_ACIN = 4.6v
                  Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                  Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                  Pin 12 PP3V42_G3H = 3.42v
                  Pin 13 CHRG_RST_L = 3.3V
                  Pin 14 SMC_BC_ACOK = 0.8V
                  Pin 19 PP5V1_CHRG_VDD = 5.05V
                  Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                  04-01-2024, 01:02 PM
                • Rezendes
                  Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                  by Rezendes
                  Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                  I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                  The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                  05-10-2024, 02:18 PM
                • pcbmaniac
                  MacBook A1278 (3115) No PPBUS_G3H Issue
                  by pcbmaniac
                  Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                  I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                  1. U7000 Measurements:
                    • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                  2. Resistors:
                    • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                  Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                  • If I also decide to replace the SMC, do I need to order it pre-programmed,
                  12-02-2024, 04:12 PM
                • sizar00740
                  macbook pro 13 inch a1278 820-2879
                  by sizar00740
                  please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                  07-30-2025, 10:21 AM
                • envym
                  by envym
                  Hi everyone!
                  06-27-2025, 08:54 AM
