Macbook Air M1 a2337 - 820-02016
  • obelix24
    • Jun 2023
    • 317
    • Slovakia
    I'm working on Macbook air a2337
    It's stuck on 5V.
    I've replaced both CD3217B12 IC's and U8100
    When i connect USB-C ampmeter i'm getting 5V 0.01 - 0.4a and restart ampmeter and again ....
    I tried to connect to another mac and i'm not able to get it to DFU.
    history is that this macbook just died randomly and owner was not able to start it again.
    PPBUS_AON is 12.3V
    i'm missing PP5V_S2 - 0V
    According to repair wiki i've checked https://repair.wiki/w/MacBook_Air_A2...a_at_5V_repair
    I can see there is heatspot at U0500.
    Any idea how to proceed ? I don't have another donor board (a2337) but i have 2x a2338 (macbook pro) they i hope have lot of same components.
  • mon2
    • 16656
    Remove all power. Meter in resistance mode. What is the exact resistance to ground of PP5V_S2? Being 5v - could be related to a USB VBUS failure.
    What is the voltage to ground of P5VS2_EN? This is the enable signal for the same power rail.
    • obelix24
      • Jun 2023
      • 317
      • Slovakia
      PP5V_S2 - resistance to ground 5M(mega) ohms and falling down
      P5VS2_EN - resistance to ground is OL
      • mon2
        • 16656
        Do you have a voltage on P5VS2_EN ?
        • obelix24
          • Jun 2023
          • 317
          • Slovakia
          yes when power is connected and testing on test point next to RC333 there is 1.8V
          I just noticed strange thing.
          When power is connected to bottom (DFU port) here it's restarting ampmeter and here I have 1.8V on PP5S2_EN
          but when I connect power to the other port there is 0V on PP5S2_EN and ampmeter is not restarting
          • mon2
            • 16656
            When there is an ENABLE signal to this regulator, do you see a voltage @ PP5V_S2? If not, suggest to replace UC300 which may be defective.
            Replace with the exact same part (Aliexpress):
            LT8642EV-2#PBF
            • obelix24
              • Jun 2023
              • 317
              • Slovakia
              Is it not possible that one CD3217 is defective ? as one port it restarting ampmeter (there is 1,8V on PP5S2_EN) and second port is stable 5V (not restarting ampmeter) but here i have 0V on PP5S2_EN ?
              Or this can be related to UC300 ?
              • obelix24
                • Jun 2023
                • 317
                • Slovakia
                i tried to replace UC300 from a2338 but it's behaving same (one port restarting, other stable both 5V)
                • mon2
                  • 16656
                  Replace the port controller that is power cycling:
                  https://logi.wiki/index.php/CD3217_a...er_on_Sequence
                  • obelix24
                    • Jun 2023
                    • 317
                    • Slovakia
                    I tried to replace CD3217 3x and it's still doing the same (restarting) I also replaced U0500 as it's the only thing pulsing but also it's still the same and there is still hotspot on U0500
                    I've checked diode mode on U0500 and they're all looking ok
                    PP1V8_AWAKE - 0.319
                    I2C_SEEPROM_SCL - 0.323
                    I2C_SEEPROM_SDA - 0.323
                    P1V25_AWAKE_IO - 0.263
                    • obelix24
                      • Jun 2023
                      • 317
                      • Slovakia
                      Is it possible that M1 is dead ?
                      I'm checking values from : https://repair.wiki/w/MacBook_Air_A2...a_at_5V_repair
                      • Check for shorts to ground on outputs of U8100 and U7701: How to find short circuits
                        1. L8100 / L8101 / L8102 (PPVDD_PCPU_AWAKE) (Figure 1) - Normal diode mode to ground reading ~0.007 / ~45Ω (Resistance)
                        2. L82B0 / L82B1 (PPVDD_ECPU_AWAKE) - Normal diode mode to ground reading ~0.114 / 140Ω (Resistance)
                        3. L8270 / L8271(PPVDD_CPU_SRAM_AWAKE) - Normal diode mode to ground reading ~ 0.116 / 450Ω (Resistance)
                        4. L8120 (PPVDD_SOC_S1) - Normal diode mode to ground reading ~ 0.012 / 110Ω (Resistance)
                        5. L8110 / L8111 / L8112 (PPVDD_GPU_AWAKE) - Normal diode mode to ground reading ~ 0.010 / 35Ω (Resistance)
                        6. L8280 / L8281 (PPVDD_DISP_S1) - Normal diode mode to ground reading ~ 0.055 / 233Ω (Resistance)
                        7. L8290 (PPVDD_DCS_S1) - Normal diode mode to ground reading ~ 0.176 / 310Ω (Resistance)
                        8. L84E0 - (PP1v4_LDO_PREREG) - Normal diode mode to ground reading ~ 0.285 / >30kΩ (Resistance)
                      And I have different values
                      L8100 - 28.6 ohm / 0.044
                      L82B0 - 107.5 ohm / 0.198
                      L8270 - ohm not measurable it's jumping between kilo ohms, ohms megohms / 0.271
                      L8120 - 26.2 ohm / 0.043
                      L8110 - 24.8 ohm / 0.046
                      L8280 - 143.5 ohm / 0.208
                      L8290 - 220.5 ohm / 0.277
                      L84E0 - 1.6 M ohm /
                      • sikocan
                        • Oct 2019
                        • 356
                        Are you able to charge battery manually and power it up with battery alone? Just to see if it works? Also do physical inspection of the port, pull it out to see if there is any corrosion on pins? Last 2 cases were just that.
                        • obelix24
                          • Jun 2023
                          • 317
                          • Slovakia
                          I tried different port the same. Also tried charge battery but still not powering on.
                          • sikocan
                            • Oct 2019
                            • 356
                            Does cd3217 needs to be pulled from another board from same position? They have an order?
                            • mon2
                              • 16656
                              Yes.
                              https://boards.rossmanngroup.com/thr...o-power.64580/
                              • obelix24
                                • Jun 2023
                                • 317
                                • Slovakia
                                I've replaced CD3217 from donor from same side.
                                • berlincaps
                                  Macbook Air M1 A2337, no charging and then no backlight
                                  by berlincaps
                                  Dear BADCAPS Forum,
                                  I am happy to have found this place and would love to get some input on my issues with a MacBook Air M1 (A2337).
                                  A couple of days ago, I was using the MacBook on a low battery, and while running VS Code it shut down due to low battery. I rarely let it reach the point where it turns itself off, and if it does, I usually charge it immediately. This time, however, I left it uncharged until the next evening, and when I plugged it in, nothing happened. I waited until the following day, and still nothing.
                                  I followed all the recommended troubleshooting...
                                  01-10-2026, 10:34 AM
                                • Guest
                                  MacBook Air M1 (A2337 / 820-02016) dead - no power, DFU restore fails after iBSS send, good voltages - NAND dead?
                                  by Guest
                                  Hi everyone, first post here – long-time reader though. I have a dead MacBook Air M1 (2020) that won't charge or power on.
                                  Device info:
                                  MacBook Air (M1, 2020)
                                  Model j313ap (A2337, logic board 820-02016)
                                  Symptom:
                                  No charging, no power on at all.
                                  Restore attempts:
                                  Apple Configurator finds the MacBook in DFU mode, as Linux with lsusb: Bus 001 Device 021: ID 05ac:1227 Apple, Inc. Mobile Device (DFU Mode).
                                  It looks like the MacBookAir is in firmware boot loop. I have tried to restore 14.x version and 26.2 (latest) version firmware,...
                                  01-14-2026, 05:01 AM
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                  🛠 Original Issue
                                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • ub6ib969
                                  Macbook Air a2337 820-02016 does not charge or detect battery.
                                  by ub6ib969
                                  HI,
                                  Macbook air a2337 820-02016 logic board does not charge or detect battery information in system. When charger is connected my usb-c meter displays 19V 0.14-0.52amps. Apple service diagnostic test return error PPP007 "There may be am issue with the power adapter".
                                  * I have already replaced U5200, no changes.
                                  J5150 (battery disconnected)
                                  pin 1 PPVBAT_AON_CONN = 00.19v
                                  pin 2 PPVBAT_AON_CONN = 00.19v
                                  pin 3 I2C_SMC_PWR_3V3_SCL = 3.26v
                                  pin 4 I2C_SMC_PWR_3V3_SDA = 3.26v
                                  pin 5 SYS_DETECT_L = 0v
                                  pin 6 GND = 0v...
                                  06-12-2026, 01:39 PM
                                • mkdj
                                  MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                  by mkdj
                                  About me, my goal and the equipment I (don't) have:
                                  I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                  About my issue and my goal:
                                  A friend of mine has a MacBook Air M1 A2337 that does not...
                                  04-03-2025, 08:28 AM
