Apple Macbook Air M1 A2337 Trackpad problem
  • Skrndelj
    • Dec 2022
    • 7
    • Serbia
    Hello all,
    I am repairing a Macbook A2337 and i have a problem
    The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
    When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
    I inspected the whole board and everything seems fine.
    Can anyone help me as i didn't fiddle with trackpad circuits on any Macbook to point me in the right direction?
  • mon2
    • 14795
    No liquid damage?
    Fans running at high speed? Inspect the trackpad cables and mating connector.
    Inspect the nand flash for corrosion.
    • Skrndelj
      • Dec 2022
      • 7
      • Serbia
      Originally posted by mon2
      No liquid damage?
      No liquid damage, i inspected the whole board, fans are not running at high speed, both NAND's look good and get 2.5V, not shorted.
      Also connector looks brand new, no gunk or bent pins or oxidation, as per my post i replaced both trackpad and trackpad flats that are known good, also i inspected the board that connects keyboard and backlight with the trackpad flat, also tried replacing that little board but outcome is the same
      • mon2
        • 14795
        Are the replacement trackpads compatible with this logic board? Each is from this specific model?
        MacBook Air 13" (A2337, Late 2020) Trackpad (ifixit.com)
        • Skrndelj
          • Dec 2022
          • 7
          • Serbia
          Yes, all are from A2337, the original trackpad that was on the device i connected it to another board and it works, so its 100% on the MOBO.
          I measured every pin on the trackpad connector and nothing is shorted
          • mon2
            • 14795
            Suggest testing each connection of the trackpad connector using diode mode measurements. Red to ground; black meter probe to the contact on the trackpad connector. Compare the diode mode measurement against a known good board. There must be a difference between the working and non-working trackpad measurements.
            • Skrndelj
              • Dec 2022
              • 7
              • Serbia
              I just did that, IPD_SPI_INT_CONN_L is too low, i then inspected RT364 which is 100K ohms and its good, also UT365 which i replaced heroically and its still the same, then i inspected RT363 which is 10K ohms and resistance is also good. After those components it goes directly to the CPU
              • mon2
                • 14795
                What is the peak current draw on the USB Type C meter for this non-working laptop board?
                What is the voltage to ground on each side of LT400? LT403?
                • Skrndelj
                  • Dec 2022
                  • 7
                  • Serbia
                  Board is "working", its stuck in Restore, uts drawubg 20V and from 0.20 to 0.9A as the battery is full
                  • mon2
                    • 14795
                    Are you using a known good battery on this target board?
                    • Skrndelj
                      • Dec 2022
                      • 7
                      • Serbia
                      Yes, Everything except the board works, i took a whole topcase that i know is good and put the board in there
                      • mon2
                        • 14795
                        Measure the power rails used by the trackpad.
                        What is the voltage to ground on each side of LT400? LT403?​
                        • Skrndelj
                          • Dec 2022
                          • 7
                          • Serbia
                          Sorry for the late response and also thank you for helping me, i measured LT400, LT402 and LT403, so PPBUSAON, PP5V and PP3V3, i don't have a single voltage
                            Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View
                            Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View...
                            10-01-2024, 05:24 AM
                          • tommy97
                            Apple MacBook A2337 - No backlight
                            by tommy97
                            Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                            The laptop was tested with fully working screen.
                            PP5v_BKLT_A/B 5V
                            PP5v_BKLT_D 5V
                            PP5V_S2 5V
                            PP5V_SW_LCD 0.4V
                            P5VS2_PWR_EN 1.8V
                            P5VS2_BST_R 8V
                            P5VS2_SW 5V
                            PPBUS_5VS2_VIN 5V
                            PPVOUT_LCDBKLT - Doesn't short 0V
                            FP800 - Both sides 12v
                            BKLT_EN_R & BL_PWR_EN - around 1.8v
                            LP800 0.014V On both sides (should be 12? / no short)
                            UC300 & UP800 Replaced...
                            12-02-2024, 08:26 AM
                          • Guest
                            A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                            by Guest
                            Hello all!
                            Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                            After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                            09-26-2024, 03:31 AM
                          • rounin
                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                            by rounin
                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                            🛠 Original Issue
                            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                            04-19-2025, 01:18 AM
                          • No Lan
                            [Macbook pro A1708] [Boot loop] [Trackpad ?]
                            by No Lan
                            Hey everyone,
                            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                            05-24-2025, 03:09 PM
