Fault source of a short circuit
  • rumpumpel1
    • Jul 2019
    • 162
    • germany
    I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
    Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities.
  • reformatt
    • Feb 2020
    • 1495
    Yes, I have had inter layer shorts on quite a few laptops. It most commonly seen when there is carbonisation of the PCB in that area so the layers breakdown and one or more layers short to an intermediate ground plane. Seen it happen on a MAC motherboard with corrosion on a main rail decoupling capacitor. It carbonised the pad and layers underneath causing the main power to be shorted.
    But it can also be due to a manufacturing defect when the VIA's are installed. If the VIA carries a lot of current, and the VIA has some level of resistance, then it will generate heat over time (remember that P=I2R). As the laptop ages, the heat from this small resistance will slowly cause damage to the VIA and it's resistance will continue to go even higher over time. Eventually the resistance is high enough that there is sufficient heat generated for the PCB to carbonise around it, causing an interlayer short.
    I had this on a Razer R209 laptop recently near the fan connector. 4 VIA's with nothing else around them, no liquid damage, you could see the board was burnt. Main power rail was shorted to the ground plane and I can only assume that was a manufacturing fault.
    • rumpumpel1
      • Jul 2019
      • 162
      • germany
      interesting, the Wikipedia article about VIA explains it quite well.
      These are pictures of both sides of the mainboard.
      Click image for larger version  Name:	20251025-143008.jpg Views:	0 Size:	379.4 KB ID:	3751044 Click image for larger version  Name:	20251025-142517.jpg Views:	0 Size:	394.4 KB ID:	3751045
      • 2Stupid4U
        Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
        by 2Stupid4U
        Laptop data:
        NTB Acer An517-51 FHD
        i7-9750H
        16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
        1TB SSD
        RTX2060
        Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
        Search gave me no hits so this is my first post.
        My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
        Since I am on a low budget I cannot afford to buy...
        08-29-2023, 01:03 AM
      • aaronkatrini
        Help me find the short circuit on this WORKING Nvidia GTX1650
        by aaronkatrini
        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
        04-18-2024, 03:15 PM
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
      • Tarot Superstars
        Short Circuit tester
        by Tarot Superstars
        Hello.
        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
        Link
        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
        https://www.youtube.com/watch?v=0eixDdCpiO4
        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
        09-25-2023, 09:11 AM
      • fab13
        Nintendo Switch lite charging chip heats up and does not short circuit
        by fab13
        Hello everyone
        Small technical problem on a Nintendo Switch lite
        Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
        After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
        When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
        Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
        09-16-2023, 04:59 AM
