Lenovo Ideapad 3 15IIL05 NM-D031 +3VALW missing
  • FrozenHaxor
    • Jun 2015
    • 266
    • Poland
    Having an issue troubleshooting this board, it takes no current. PQ100 MOSFET gets 0V on the gate and does not open, when I short it out the laptop powers up. There is 0V on ACDRV from BQ24780, 0V on ACOK.
    Now for the fun part, ACOK is pulled up to 3VALW rail, when I short out the PQ100 and power up the laptop, ACOK jumps up to correct 3.3V, as soon as I remove the short across the MOSFET it goes fully dead again. Now my issue is that according to schematic this is a circular logic, I can't have +3VALW without getting power to the PU1101 SY8386BRHC, but I can't get power to that chip unless PQ100 opens and powers up the main PR100 resistor. The internal LDO of BQ chip works and outputs 6V so it gets the power. ACDET is at 2.72V
    What am I missing?
    Schematic and BoardView: https://www.badcaps.net/forum/troubl...59#post1654359
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Many others measurements to take.
    PQ101 is it OK (Diode mode)
    PR100 measure with resistance mode
    PU100 voltages : PIn 3 /4 /5
    • FrozenHaxor
      • Jun 2015
      • 266
      • Poland
      PQ101 is okay
      PR100 is good (0.03Ohm)
      PU100 pin 3 0V
      PU100 pin 4 0V
      PU100 pin 5 0V
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        PR100 resistance to GND to know if there's a short at 19v rail
        you can also check all colis for short
        what do you mean by : when I short it out the laptop powers up....is there a display !
        • FrozenHaxor
          • Jun 2015
          • 266
          • Poland
          There is no short. When I bypass PQ100 MOSFET (connect drain and source together) I get the laptop to fully power up.
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            If there's no short at your motherboard , all coils are not shorted so i suggest to concentrate more at BQ24780S.
            This forum is full of informations about it.
            from my opinion , if i had 19v at pin 28 / 2.7v at pin 6 / 6v at pin 24 ...so i must find my 6v at pin 5 ( ACOK is pulled up to 3VL rail and not 3VALW rail in general )...and there's no short to gnd at BQ pins....so i change it simply .
            ACOK must be 6V in this case get it from BQ24780_VDD
            Is PR112 /PR111 populated at this motherboard !!
            • FrozenHaxor
              • Jun 2015
              • 266
              • Poland
              ACOK can't be 6V, it's pulled up to the +3VL rail only. It goes to 3.3V when I bypass the MOSFET and boot the board.
              There is no PR112 or PR111 populated.
              • FrozenHaxor
                • Jun 2015
                • 266
                • Poland
                Case closed, replaced faulty BQ chip, it was not driving the PQ100's gate at all. Replaced PQ100 preemptively as well if it turned out to be the cause of BQ's failure. Power rail sequence is now correct. Thanks for the support.
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  Good news
                  Can you please share the BQ voltage
                  • FrozenHaxor
                    • Jun 2015
                    • 266
                    • Poland
                    Good news
                    I put the laptop together already, but the gate drive voltage from ACDRV was a nice 24.7V as it should be, ACOK at correct steady 3.3V, ACDET at 2.7V.
                    • Kshi
                      acer a515-52g-4830 5valw 3valw missing
                      by Kshi
                      hello,
                      this is my third time trying to revive dead laptops.
                      I got this acer does not have power light
                      First I test
                      dc 19v-ok but +5valw and +3valw is missing
                      i remove the board to test more but i didnt find anything
                      no shorts no corrosion
                      but i get +3vlp and +5vlp present
                      and now i dont know what to do anymore
                      hope someone can help me and improve my skill
                      Link to schematic - https://www.badcaps.net/forum/troubl...nd-mobile-devi...
                      07-24-2025, 12:22 PM
                    • ugamazing
                      820-02020 PPBUS_AON missing
                      by ugamazing
                      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                      02-05-2025, 04:21 PM
                    • Evgenii999
                      Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
                      by Evgenii999
                      I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
                      Symptoms:
                      The laptop does not power on and does not respond to the power button.
                      Background:
                      According to the owner, her child was playing on the laptop when it suddenly shut down.
                      What has been done so far:
                      Original charger is missing; the non-original one was tested and found faulty (0 V output).
                      Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
                      10-25-2025, 06:07 AM
                    • jpreza
                      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                      by jpreza
                      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                      Looking at the card, it appears to be missing the following:
                      1x 1.0uH inductor - orange square
                      2x...
                      11-01-2024, 10:54 PM
                    • BYTEHAT248
                      Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                      by BYTEHAT248
                      Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                      11-14-2025, 04:48 PM
