acer a515-52g-4830 5valw 3valw missing
  • Kshi
    • Aug 2024
    • 20
    • Philippines
    Originally posted by mon2
    Confirm that VDD_CHG is present on the one side of PR311. This is important. Measure this voltage to ground.
    VDD_CHG to ground is 5v
    • Sephir0th
      • Oct 2020
      • 1289
      Best bet is to replace the charging controller i would say since nothing else is off at this point.
      Fingers are crossed
      FairRepair on YouTube
      • Kshi
        • Aug 2024
        • 20
        • Philippines
        Ordered new charging IC, I will update you guys when I replaced it. Thank you for helping me
        • Kshi
          • Aug 2024
          • 20
          • Philippines
          Update: Replaced charging ic but still the same🥲 also replace 1st and 2nd mosfet
          • mon2
            • Dec 2019
            • 14677
            Carefully measure the voltage to ground on each pin of the charger IC and post each here in a table with pin # and function name for a review.
            • Kshi
              • Aug 2024
              • 20
              • Philippines
              #26
              1-ACIN 4v
              2-ACOK 0.06v
              3-SDA 0v
              4-SCL 0v
              5-PROCHOT# 0v
              6-AMON 0v
              7-BMON 0v
              8-AGND 0v
              9-PROG 0v
              10-COMP 0v
              11-CCLIM 1.6v
              12-FSET 0V
              13-BATGONE 0v
              14-CSON 0v
              15-CSOP 0v
              16-ACLIM 1.3v
              17-NTC 0.9v
              18-DCIN 18.7v
              19-VDD 5.2v
              20-VDDP 5.2v
              21-LGATE 0v
              22-PHASE 0v
              23-UGATE 0.1v
              24-BOOT 4.8v
              25-BGATE 0v
              26-VBAT 0v
              27-QPCP 4.8v
              28-OPCN 0v
              29-CMSRC 0v
              30-ASGATE 0v
              31-CSIN 0v
              32-CSIP 0v
              • mon2
                • Dec 2019
                • 14677
                Remove all power. Meter in resistance mode. Confirm that you have a resistor @ PR311. Measure the resistance across this resistor.
                Confirm you have a resistor @ PR313. Confirm the resistance across PR313.
                Confirm that PR311 is mated to pin # 19 of this charger IC @ PU301. This is the pull-up voltage rail.
                Together, PR311 & PR313 build a voltage divider and will offer a parking voltage on ACOK pin IF the adapter voltage is considered to be OK. The ACIN pin #1 voltage is high enough so ACOK should offer a valid voltage. If ACIN is too low, then ACOK will be pulled low but do not believe this is the case. Rather, suspecting that the external resistors or soldering is missing for PR311.
                Confirm it.
                • Kshi
                  • Aug 2024
                  • 20
                  • Philippines
                  #28
                  PR311 74K
                  PR313 93K
                  PR311 have continuity to pin#19
                  • mon2
                    • Dec 2019
                    • 14677
                    This should be ok. Have you used the same part for the replacement for PU301?
                    What should happen here is that the ACIN voltage on pin #1 must be at a specific voltage or higher. This is the voltage from the power adapter. You are at 4v and this should be ample to consider the adapter to be at a suitable voltage. Then ACOK pin # 2 should be floating or open-drain (like an open switch). Then these external resistors will create a lower but safe voltage to apply onto the floating pin #2 line. This floating voltage will then enable other mosfets on the board (2N7002) to perform their task.
                    Are you comfortable with the soldering of PU301? Consider to reflow it if in doubt. Flux & reflow to be sure that there are no shorts linked to pin #2.
                    The alternate theory is that the voltage on pin #1 is too low and for this reason, pin #2 is being pulled to a low voltage to indicate the power adapter is NOT suitable. For now, do not believe this is the fault.
                    Remove all power. Measure the resistance to ground of pin #2 on the charger IC. We are testing for any possible shorts. Perhaps your PR313 measurement above is the same measurement?
                    Sorin is working on the same unit(?) here:
                    https://www.youtube.com/live/9MB34gNQceQ
                    Be sure your pin #1 on the charger chip is correct.
                    • mon2
                      • Dec 2019
                      • 14677
                      ACIN is a bit higher than the calculator shows but do not believe this should be an issue. The full datasheet for this charger IC is not public so not 100% sure if the adapter voltage is considered to be too high or not.
                      • Destroyer-Br
                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                        by Destroyer-Br
                        I'm working on an Acer Nitro 5 unit with the following specs:
                        • Motherboard: LA-J871P Rev: 1B
                        • Model: Acer AN515-55-59MT
                        • S/N: NHQ7JAL00403906A973400
                        • SNID: 03902728734
                        Initial Issue
                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                        04-17-2025, 08:18 PM
                      • FrozenHaxor
                        Lenovo Ideapad 3 15IIL05 NM-D031 +3VALW missing
                        by FrozenHaxor
                        Having an issue troubleshooting this board, it takes no current. PQ100 MOSFET gets 0V on the gate and does not open, when I short it out the laptop powers up. There is 0V on ACDRV from BQ24780, 0V on ACOK.
                        Now for the fun part, ACOK is pulled up to 3VALW rail, when I short out the PQ100 and power up the laptop, ACOK jumps up to correct 3.3V, as soon as I remove the short across the MOSFET it goes fully dead again. Now my issue is that according to schematic this is a circular logic, I can't have +3VALW without getting power to the PU1101 SY8386BRHC, but I can't...
                        10-16-2025, 05:58 AM
                        09-06-2024, 05:27 AM
                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-07-2024, 05:00 AM
                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
