Missing Component
  • doread
    • Jan 2014
    • 6
    • US
    Missing Component
    Hello, I am currently fixing a laptop that was bashed against a wall repeatedly. I fairly sure I have the laptop working now, but I noticed it was missing a component.
    The missing component is is near the HDMI port. There are 3 still there. I have yet to actually test the HDMI port. Anyone know what this is or how I can find a replacement?
    I have a fairly good junk pile I can salvage from.
    Thank you
    Laptop info;
    Toshiba Satellite L870
    Model: PSKFLC-00N007
    Pictures are on google drive, main one ends in -c
    https://drive.google.com/folderview?...Vk&usp=sharing
  • doread
    • Jan 2014
    • 6
    • US
    Re: Missing Component
    Update;
    HDMI port did not work. I pulled a component from another older toshiba laptop and it is working now. (same place, in front of HDMI port)
    My best guess is that it is a SMD Inductor since I can see copper wire. The component I replaced it with does look a little different.
    Should it be OK? I am giving it to a relative, so I can service it later down the road if something happens.
    Thank you!
    • SteveNielsen
      Retired Tech
      • 2327
      Please post pictures directly to this site instead of linking to another.
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        well inductures are read on Henrys , and usually its good to use the correct values , but if you can order the right part , order it , if don't well warn your client about risks and leave him choose the option
        • doread
          • Jan 2014
          • 6
          • US
          Sorry, I can't seem to post attachments. What are the risks of using the wrong values?
          edit; managed to get 2 attachments uploaded.
          I will put the laptop together and stress test it today. See if it keeps working after hours of HDMI use. I will also use my spare TV to be safe.
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            yes indeed make some test , dont forget that inductor , induce corrent . so chek also if the component itself get to much hot . and stress well the port .
            • doread
              • Jan 2014
              • 6
              • US
              I tested the port and no issues, it worked great for hours. My new issue is that the second/top ram slot doesn't seem to work.
              I thought it was working before I started the work. I will take it apart again later and see if there is anything obvious.
              Thanks for your help
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                chek with one ram stick , try in both sockets and see if both work , could be bad ram , or maybe bad mem controler
                • doread
                  • Jan 2014
                  • 6
                  • US
                  I tried all combinations, only the bottom dimm works. I put a 8GB stick in the working slot and it has been working so far.
                  Assuming it continues working, I am not going to bother trying to fix it.
                  Thank you for your help.
                  • ugamazing
                    820-02020 PPBUS_AON missing
                    by ugamazing
                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                    02-05-2025, 04:21 PM
                  • jpreza
                    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                    by jpreza
                    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                    Looking at the card, it appears to be missing the following:
                    1x 1.0uH inductor - orange square
                    2x...
                    11-01-2024, 10:54 PM
                  • gurj1979
                    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                    by gurj1979
                    Hey guys.
                    Need help with this one.
                    Fan not spinning due to missing PWN Fan signal.
                    Also 5 seconds from powering up it freezes, unless in BIOS.
                    But as soon as Windows starts to load, it will freeze.
                    CPU is COLD / Room temp when it freezes.
                    I've replaced the CPU, same problem.
                    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                    Replaced fan - same problem.
                    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                    08-19-2024, 05:22 PM
                  • salopian
                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                    by salopian
                    Hello. I would need some advice please.
                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                    I have already replaced the logic board with another...
                    02-27-2021, 07:30 AM
                  • reessi
                    HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                    by reessi
                    I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                    It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                    What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                    I have checked these lines in diode mode and they seam normal -> 600.
                    I have checked to see if they come on for even a fraction of a second...
                    07-15-2025, 09:14 AM
