da0r75mb6cd0 REV: C problem.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    #41
    Re: da0r75mb6cd0 REV: C problem.
    also following the EC rom pinout there is a line right after R302 , that goes down and will connect to FDIO2 to KB , and there is 0 volts on the KB as well .. but FDIO 3 that connect to pin 7 allready have 3.3 .. i dont know if this its relevant or not . but let me chek injecting 3.3 volts on the pin (makes no sense , since the resistor is ok , it should pass , but let me try
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      #42
      it will give a bit of voltage on the pin 3.04 , but make the KB to start to be warm(not hot)
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        #43
        bios voltages ..
        1- 3.35
        2 - 1.50
        3 - 0 (but if i lift the pin 3 , and if i measure the in 3 directly i got qround 1.79)
        4 - 0
        5 - 0
        6 - 0
        7- 3.3
        8-3.3
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          #44
          after a update on bios
          gt diferent value
          pin 1 is 0v
          pin2 is now 3.03
          pin 5 -2.90
          pin 6 - 0
          all the outher are the same
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            #45
            This chip could be broken. For normal operation, pin 3 should be high. Can u measure the resistance of pin 3 with tespect to ground?
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              #46
              i will tomorrow , it was my day off today when you mean broken chip (you mean the rom ?
              tomorrow i'll let you know
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                #47
                with the rom soldered to the board , pin 3 to ground 24.6 ohm .. sounds a bit low
                • highpulse
                  i hate HP
                  • May 2013
                  • 1488
                  • portugal
                  #48
                  well sodlered a new chip on it , pin 3 now i got 75Kohm . but still 0 volts ... but pin 2 i got 3.34 volts .... each time more crazy really dont get wtf is going on
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    #49
                    using dso, is there any activity on pin 1,2,5 and 6? you may need to flash a known working rom.
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1488
                      • portugal
                      #50
                      will use one that a friend sent me here , just in case , i tryed so many allready . will relfash with the F33 that someone sent me here
                      in this moment , (only thing i can measure is voltage since i got a lack of osciloscope in the lab -.. piggy boss :\ ) but for voltages on the pins you request , all are 0 except for pin 2 that is 3.35
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        #51
                        even with bios lifted , all the voltages i mention , are there
                        3:35 volts on pins 8 , 7 and 2 ..all the outher got 0 volts :!
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          #52
                          ALEEEE LUIAAAAAAA
                          thk to Atsio dumps finally i can deliver this thing to my client !!!! dammmmmm it was hard but working nowww !!!!!
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            #53
                            ni the END all this shits was ITE and charger problems .. and after to much reflashing bios , i ended up damaging the previous bios .. with the new chip i had a different value and with the F33 dump by Atsio once i connected the dc source , if flashed the led then it light up the led , and its turning on
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              #54
                              well the bido 1982 turn on but no image .
                              bido 2139 turn on led of dc jack , but doesn't allow me to turn on machine .
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                #55
                                also tried the f22 version from dyce but , the same turn on no image. ohh bloody machine !!!!
                                tomorrow will spend more time with this bastard
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  #56
                                  btw this is a UMA version it only have the FCH amd chipset.
                                  Techman (your the bios pro here ) could this bios dump making this issue to happen ? have you time to create one ? for me
                                  HP 15-E050SP
                                  product D9X89EA#AB9
                                  board model is the one mentioned on the topic
                                  but anyway its the - DA0R75MB5C0 REV:C
                                  there is only AMD cpu , and FCH chipset
                                  KBC ITE IT8528E
                                  ROM is a 32 mb
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    #57
                                    ok troubleshotting the problem , cheked on lvds connector , and i dont have pin 1 and 2 voltages , well noticig after that there is a component that dont exist , since there is no discrete VGA on this board .so there will be no value here since they come only from that supposed component that is not on this version.
                                    got 19 volts on the 39 and 40 pin , and 3 volts on the pin 3 of LVDS.
                                    this on page 22.-
                                    on page 33 i got here a lvds converter RTD2136R and its giving me only 0.34 volts for pin 44 LVDS_BLON (this should be at least hinger than 2 volts since its for bklight .
                                    i got the 1.2 and 3.3 sources entering into the lvds converter , but pin 19 20 and 21 i got 0 volts . and surely does would have a positive value especialy for DISP_ON (pin20)
                                    im getting tired of this board , im just still working on this , since is a good client and he spend good money on this fix for we can make it to turn on . now all good but no image is killing me .
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      #58
                                      pff any clues guys !!
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        #59
                                        i cheked that RTD2136R got all VCC coming in , 1.2 and 3.3 lines , altough there isn't any voltages on
                                        DISP_ON COMING OUT
                                        DPST_PWM COMING OUT
                                        PWM_VADJ COMING IN
                                        LVDS_BLON COMING OUT
                                        • dj_ricoh
                                          • 2073
                                          #60
                                          KBC_RST#, SUSON pin19, RSMRST#, NBSWON1#, VGA_ON_SB
                                          post some values on those pins
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
