da0r75mb6cd0 REV: C problem.
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Hi guys , got here a problem with a recent machine that enter the lab ,
    its a hp 15-e050sp the problem as charger port damaged , so we've ordered a new dc jack for it and we received we asked the client to bring us is powersupply since it is this new HP dc jack with bluetip with center pin but the smaller one, i didnt have this tip for my charger and client also was with center pin damaged , so we've bought a new charger for it , but not turning on and no dc jack led light turning on as well , usually this is bios or system charger . but would like to make some measures first before buying whatsoever i will need , but not finding this schematic to download at all , also was trying to chek pinnout for the BQ728 or also can be BQ24728 for i can know if all is ok with system charger before ordering one .
    Also notice that i really dont have 3.3 or 5 volts on coils , but that i supose its a security measure to save energy and this will be only present when S5 is enabled . i got 3.3 on on off button and drop to 0 when pressed , and also got 3.3 volts on the bios as well , possible feeded by LDO of step controler . also got 5v LDO on the step controler (meanwhile dont know wich STEP controler is this and they are 2 right near each outher .
    Now before ordering any part i would like to be more sure of what part buying , so if anyone have this board or schematic that can give me some pin values for the Charger ic i would be very greatful
    meanwhile i leave here the values i got on the charger IC :
    1- 19.8v
    2- 19.8v
    3- 19.8v
    4- 24,9v
    5- 2.8v
    6- 2.5v
    7- 0
    8- 3.2v (between 3.1 and 3.2)
    9- 3.2v (between 3.1 and 3.2)
    10- 3.1v
    11- 2.5v
    12- 2.5v
    13- 2.5v
    14- 0v
    15- 0v
    16- 5.8v
    17- 5.8v
    18- 2.4v
    19- 2.4v
    20- 19.8volts
    PS - also donwloaded bios from the hp site , inside of the exe file , there were 2 .bin files with same size just different dates , i saved the dump and tryed with both , still the same so i can see bios is not the problem .
    Wait for some good news from you guys.
    thk in advance
    jonathan
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: da0r75mb6cd0 REV: C problem.
    Check voltage on pins 1, 6 and 12 of PU12 and PU13
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      ok wi.ll do it now
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        pin 1 .19.8v on both pu12 and 13
        pin 6 pu12 3.2 v
        pin6 pu13 4.9 V
        seems ok
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          im divided between charger ic and KB ...but would like to be more sure about whats is causing this issue
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            ATsio do you have this schematic or a board with you»?
            • atsio
              • Oct 2013
              • 819
              • Greece
              Do you have an osilloscope? If yes check for data signals at pin 1 of U13 and U14.
              Check voltages on pins 11,18,21,69,71,74,125,127 of ec controller and pin 5 of DC jack
              • khaahk
                • Dec 2013
                • 812
                • Estonia
                Schematic rev 1A
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  A working board returning to customer tomorrow.
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Originally posted by khaahk
                    Schematic rev 1A
                    Thanks for the schematic
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1490
                      • portugal
                      EC
                      11- 0v
                      18- 3.35v
                      21- 2.97v
                      69- 2.76
                      71- 0.78
                      74- 3.34
                      125 and 127 - 3.34v
                      pin 5 dc jack 0.04v ( the pinout is not very seenable but since it show me pin 2 and 8 i assume that pin 5 is the one i measure
                      onfortunetly , i work for a shop that its very hard to make them buy me gear to work even some of the stuff i've got its frmo my place .....
                      but very soon will leave this and open busyness with a colegue. so for DATA signal i cant help you atsio , sorry.
                      khaahk thk for schematic
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1490
                        • portugal
                        seems not having +3v for ec controler .
                        well it will bve normal since this voltage i will only have after s5 enable (due to step controler not beeing sending 3.3vs5 and +5vs5
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          Do you have the discrete or uma version of the board?
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            Atsio since there is no GPU dedicated to this so its a UMA
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              As you imagined, probably problem with IT8528 but first check and the second bios ic (U13) with the programmer if it is allright.
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1490
                                • portugal
                                there is only one bios here , u13 u14 same place only one ROM , 25q32fv winbond donwloaded from HP site the EXE file have 2 Bin files , tryed both (they have 4.3 mb , but still the same , flashs ok , no errors .
                                could this be a damaged rom IC ? will replace with the exact size in mb rom chip with another and reflash to see , if no news , well guess then ITE is doomed
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1490
                                  • portugal
                                  or if you have a good dump for this ROM and you can share just to make sure i apreciate in advance
                                  • dycc
                                    Vision
                                    • Nov 2011
                                    • 625
                                    • Côte d'Ivoire
                                    I recommend flashing u13 first
                                    got one with same issue one day and flashing ec bios solved it
                                    • dycc
                                      Vision
                                      • Nov 2011
                                      • 625
                                      • Côte d'Ivoire
                                      Ok bios
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1490
                                        • portugal
                                        Dycc thk you for the rom , alltough this one had issues with DC jacket all pins were messed out and damaged charger as well , let see if your dump save me time for my client will flash it now
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
