da0r75mb6cd0 REV: C problem.
    Re: da0r75mb6cd0 REV: C problem.
    well rom ic is sstarting to give problem , after flashed with your rom, gave error in the End on buffer adressing , i tough could be something with bios or bad contact with bios , so recheked and tryed to revert and insert the actual dump insyde also gave error , so this IC rom is doomed for sure , im gonna try with a sst25vf032b also 32mb let see what happen
      with new chip , flashed , but no joy , still same not turning on or turning on LEd on dc jack
      will reflash with my dump , now if not working then must be ITE problem , since all the rest seem fine for me and for the outher who have been following the case
        Two
          well no joy :S with my dump or with your dump
            dycc same with the rom as well , tryed all the same for all ,
            seems bad ITE
              Ec have to be flashed also with programmer via keyboard line .
                how to do that ?
                  I think you can not flash an IT8528E (it is not an ENE). Some laptops require a post procedure after flashing the bios i.e. https://forum-en.msi.com/index.php?topic=112416.0
                    Atsio , then this keyboard line that dycc mention how is that done when its a ENE for ex , in the site you sent , explain that to clean EC controler it just need to remove power for 5 min , and its good to go . but what does it mean by keyboard line , tryed to google but didnt find anything relevant ? anyone could explain for future thing that may appear?
                      https://www.badcaps.net/forum/showth...kbc+programmer
                      https://www.badcaps.net/forum/showthread.php?t=38671
                        thk atsio good to know
                          THINK THIS PROGRAMMER FOR ITE MUST EXIST SINCE I SUCCESSFULLY REPLACE ITE8518(FOR HP2OOO OLD VERSION FOXCONN CHICAGO HR-HPC) BY ITE8517(ON HP 2000 NEW VERSION 6050A2493101-MB-X01) . AND THIS REPLACEMENT DOES NOT WORK ON AMD MODEL USING ITE FROM INTEL BOARD .
                          ALWAYS LOOKING FOR
                            well thats the spirit dycc , we need to be alwats looking for .
                              i got only on stock a ite8527e ... but this one onboard is a 8528e , well m main problem to make it work should have a correct bios but must find online a KBC rom for that ITE before trying it out
                              let me chek 1bios.ru
                                Try these bin files. They are the UMA and Discrete version of the decompressed bios files and their slic modified counterparts.
                                  Atsio will try out . since im still waiting for a answer of the client to order both parts charger ic and ITE , will try meanwhile , maybe i can give a hope to my client. cheers mate
                                    well no joy for nothing , received today system charger and ITE Kb controler , replaced even both and still the same , not turning on , and no LED on dc jack ... PFFF starting to be mad with this board allready
                                    TECHMAN you're the man who will make a WORKING BIOS that will make this computer to turn on !!!! i hope !
                                      another thing i noticed , i dont have 3.3 volts on pin 3 of bios .. only got on pin 7 and 8 .. and pin 5- 2.78v ...
                                      R302 not passing from one side to another the 3.3 , since i got this value on KB .. let me chek if the resistor is ok ,. should be 10K
                                        well resistor is ok , 10 K , but not feeding pin 3 of bios
                                          try to supply 3.3v to pin 3 directly.
