Defective BIOS chip
  • Pize92
    • Jul 2025
    • 8
    Defective BIOS chip
    Hello everyone.
    I have a problem.
    The BIOS chip on my Lenovo Legion 5 17ACH6H appears to be defective. I wanted to read the chip first with the ch431a programmer and then with the t48 and create a dump. However, it always threw an error during verification.
    I then bought a new BIOS chip from Aliexpress and loaded an existing dump onto the chip. With the corresponding DMI.
    Unfortunately, the laptop now keeps restarting.
    My question is, can you simply use the DMI from a foreign dump, or is the motherboard completely lost due to the defective BIOS chip?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    lenovos dont need to edit dmi. some chips need better programmer or adapter for 1.8V chips
    • m1ch43lzm
      • Mar 2019
      • 482
      • Peru
      Make sure you use a compatible 1.8v chip, Winbond W74M12JWSSIQ, W25Q128JW or equivalent
      Also try the clean BIOS from post 5 here:
      https://www.badcaps.net/forum/troubl...56#post1752856
      Will show serial/machine type as INVALID but laptop should boot
      • Pize92
        • Jul 2025
        • 8
        I wrote exactly this dump to a new chip from Aliexpress using the t48 and soldered it in. W25Q128JW was set in the program, as well as 1.8v.
        Which program would be best to use for the chip?
        • mon2
          • Dec 2019
          • 14334
          There is a 'Q' in the flash part number so it must support QSPI mode of communication. This is where 4 bits of data are transferred on each clock cycle.
          Check if the QSPI bit is enabled on the original and perhaps is not on the replacement.
          • Pize92
            • Jul 2025
            • 8
            Could this also be due to the security layer? Or can I check this?
            • mon2
              • Dec 2019
              • 14334
              Your programming s/w should offer a 'QE' bit. Review this and check this box or enable with a '1' to enable the QSPI mode. Assuming here that it is necessary. Worth testing.
              • Pize92
                • Jul 2025
                • 8
                Unfortunately, reflashing with QE enabled did not help.
                • m1ch43lzm
                  • Mar 2019
                  • 482
                  • Peru
                  Try post 9 from here
                  https://www.badcaps.net/forum/troubl...57#post3478157
                  If it works you can use this: https://github.com/Shmurkio/LenovoDMIDecryptor
                  to decrypt the DMI on the working dump, edit your S/N and MTM with hex editor (there's 2 blocks, one is a duplicate, edit both), then encrypt it again
                  QE bit should be set as the following:
                  Click image for larger version  Name:	w25q128jw.png Views:	0 Size:	64.0 KB ID:	3709147
                  Also lower the SPI clock frequency to 8MHz if using clip
                  • Pize92
                    • Jul 2025
                    • 8
                    Unfortunately, that didn't work either.
                    Now the laptop starts up for 1 minute at the beginning and then restarts every 10 seconds.
                    Every time I try to read the old BIOS chip, I get a verification error. This does not happen with the new chip. Could this be due to security Mayer? Or is the old BIOS chip simply defective?
