Asus G513QE keyboard and backlight not working
try to use that software but kisk me out because of QE model.
I replaced IT8252 but still the same.
Try to flash FW but still get no connection.
But now i found that fans are not working and they are connected to main KBCComment
Try the ROG Keyboard Firmware Tool i uploaded here
https://www.badcaps.net/forum/troubl...16#post3731516
This version has firmware for: G513IC/G513IE/G513IH/G513IM/G513IR
G513QC/G513QE/G513QH/G513QM/G513QR/G513QY
G713IC/G713IE/G713IH/G713IM/G713IR
G713QC/G713QE/G713QH/G713QM/G713QR/G713QY
I tried V2.7.3.002, main windows say "G513QE skip", update window wants press update button and than window dissappear and nothing happand. only main window.
How long can take flashing?Comment
2.73.002 only has G513IM firmware, You can extract .exe with WinRAR or 7-zip to check
2.73.001 has firmware for the models I mentioned
You can try the suggestion from this Reddit post
https://www.reddit.com/r/ASUS/commen...mment/mi550gt/
Extract the .exe then run ROGKBFWUpdateTool.exe from bootable WinPE 10/11 USB such as Hirens or Sergei StrelecComment
damn still the same. detect G513QE, skip it2.73.002 only has G513IM firmware, You can extract .exe with WinRAR or 7-zip to check
Maybe there's a way to trick the updater
I compared FGA00000.G513IH.208 to FGA00000.G513QE.208 with hex editor, the only difference inside is 2 instances of G513IH (G513QE), rest is identical, so the KB firmware is the same for all
Also checked the file from post 12, it appears to be a newer version 211 for G513IH (or all G513I/Q/G713I/Q), but it doesn't have the header/footer for the updater.
But 2.73.002 has KB firmware 316 for G513IM,, try this modded updater, I just renamed the file for G513QE and hex edited "QE" instead of "IM" in the firmware update file
EDIT: for flashing # 12 with EC programmer i think you need the P3V3A_DSW_NKEYPWR supply workingAttached Filesif you find these attachements useful please consider making a small donation to the site
Now im not sure if it is really bad second SIO or the first. As i see that fans come from first SIO and fans are not workingMaybe there's a way to trick the updater
EDIT: for flashing # 12 with EC programmer i think you need the P3V3A_DSW_NKEYPWR supply workingComment
It's going from bad to worse, first no keyboard and now no fans? Unless it's some setting in the Aura/Armory crate or whatever the ASUS software is called to control the fans, check temps to be sure, I'd worry if it gets to 80C idling
Also try "Load setup defaults" from BIOS
The second KBC looks like it's also connected to an internal USB port, to emulate a USB keyboard I presume, for Nkey support and the RGB stuff
Not sure if the first EC firmware is faulty, as the laptop powers on, I extracted main EC firmware from BIOS 331 from ASUS website if you want to try, cut to 192KB (I don't know the size of your main EC, but sure is 192KB or 256KB), backup first of course
Get the keyboard fixed first, then check the fans laterAttached Filesif you find these attachements useful please consider making a small donation to the site
thank i will try. im worried that if first sio is bad or damaged, if it does not restrict second one to comunicate or run. without functioning fans, laptop is uselessIt's going from bad to worse, first no keyboard and now no fans? Unless it's some setting in the Aura/Armory crate or whatever the ASUS software is called to control the fans, check temps to be sure, I'd worry if it gets to 80C idling
Get the keyboard fixed first, then check the fans laterComment
Does the EC part number end in -128? If yes try, cut to 128KB
I may have made a mistake cutting to 192KB, try this insteadAttached Filesif you find these attachements useful please consider making a small donation to the site
by user546087Hi,
I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
- kindly ask Asus for an adjustment - they basically told me to STFU and get lost
It is not possible, they say. Of course.
- tint the keycaps from behind - I have already tried that - it is kind of a last resort
- try to find out, how it is done, look at schematics - this is, where we are at.
- maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...02-24-2025, 02:03 AM -
by obdcartHello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
I hope you can give me some help1 Photo -
by Kambi13Hi there need some advise. I have an Asus N550JV-CN102H with board N550JV Re2.1 suddendly started to behave weird, with almost no keys working on keyboard, opening random stuff, touchpad also working weird
Nothing has been spilled. Tought, well keyboard has gone bad, ordered a replacement one, installed it, and to my surprise the issue remains the same....
I'm wondering if the EC has gone Bad. Updated Bios also, but with no avail.... Does anyone knows if ITE IT8585E/FX has to be programmed? -
by SuperAmanI have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...08-31-2024, 07:30 PM -
This specification for the ASUS ROG GX531GXR-ES007T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GX531GXR-ES007T boardview and GX531GXR-ES007T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 09:17 AM
- Loading...
