MAC A1706 NO POWER
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    MAC A1706 NO POWER
    GOOD MORNING ALL
    I HAVE THE ABOVE BOARD AND DRAWS 20V 0.087AMPS.
    PPBUS_G3H I GET 13.05V.
    I NOTICED L7960 IN DIODE MODE I GET 0.0001 ON PIN 2 WHICH GOES TO CPU. ALSO U7800 IS GETTING HOT.
    FOCUSING ON L7960 PIN 2 GOES TO C7964 WHICH SEEMS OK AND THEN DIRECTLY TO CPU.
    IS THE PROBLEM ON CPU OR U7800!
    THANKS
  • Harryrepair
    • Jul 2016
    • 82
    Gia sou, 0.00 seems low for the cpu. Check in resistance mode (OHM MODE)
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      Gia sou Harry, the resistance is very low 0.4 OHMS
      • Harryrepair
        • Jul 2016
        • 82
        indeed the resistance seems low. Try to inject into cpu and check the heat development
        • NConstantinou
          • May 2017
          • 351
          • Cyprus
          i have injected 0.7v and 1.2 amp on coil 7960 but nothing gets hot. if i increase amps the the red light from power supply goes off.
          any other suggestions.
          thanks
          • mon2
            • 14691
            Is the heatsink on the CPU off?
            • NConstantinou
              • May 2017
              • 351
              • Cyprus
              the heatsink on the cpu was off
              • mon2
                • 14691
                Meter in resistance mode. Touch your meter probes together. What is the resistance in ohms? Then measure the resistance to ground again of L7960. What is the measurement?
                • NConstantinou
                  • May 2017
                  • 351
                  • Cyprus
                  in both cases resistance is 0 OHMS
                  • mon2
                    • 14691
                    I would suspect that your CPU is dead but wait on other comments.
                    For giggles, lift up one leg of L7960. Then measure again. Which side is with the 0 ohms to ground? Maybe with some luck, it is the low side of the internal mosfet inside of U7960.
                    • NConstantinou
                      • May 2017
                      • 351
                      • Cyprus
                      Hi Mon2. How is Windsor!
                      the problem is on pin 2 on L7960. on pin 1 of L7960 i do have resistance.
                      what i have done i disolder pin 1 of L7960 and i inject voltage but nothing got warm.
                      if i connect pin 1 of L7960 then U7800 gets HOT
                      • mon2
                        • 14691
                        Hey Windsor is exponentially declining. Junkies everywhere - have had multiple attempts to break into our business.
                        When you lift up L7960 - what is the resistance to ground on pin #1? Pin #2?
                        • NConstantinou
                          • May 2017
                          • 351
                          • Cyprus
                          Pin 1 is 6.93k and pin 2 0. Junkies are everywhere today. we have a lot coming from African countries. unfortunately we work for them
                          • mon2
                            • 14691
                            To me, the CPU is dead. What used to be our downtown library is now a shelter for the homeless. Scared to even go downtown anymore. Personal pizza @ Terra Cotta down the street from your former place has increased from $12 to around $20. Pizza is outstanding but we reserve to eat it only on the '2 for Tuesday' deal - still a ~$100 investment. New owners there and also Shin Shin. Next time I am in the area, will try to take a few pics to update you.
                            • NConstantinou
                              • May 2017
                              • 351
                              • Cyprus
                              Thanks a lot for the brief info. it seems that the same story is everywhere. Here also in a few years will be minority and yesy at night you are afraid to go downdown because of these people BUT is missed WINDSOR.
                              • Instafixx
                                Macbook A2179 820-01958
                                by Instafixx
                                Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                I checked the Power Sequences below and found this -
                                Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                05-20-2023, 05:19 AM
                              • Danielreinaa
                                HELP need password bios Macbook A1706
                                by Danielreinaa
                                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                09-07-2024, 03:47 PM
                              • moderator
                                A1706 - emc 3107 bios
                                by moderator
                                a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
                                Serial number is C02STA7EHF1P
                                its A1706 - emc 3107...
                                05-17-2024, 07:00 AM
                              • capon5153
                                Macbook A1706 works perfectly but no data on USB C
                                by capon5153
                                hello,
                                so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                06-22-2025, 09:42 AM
                              • madjid911
                                A1706 No power
                                by madjid911
                                Hello, I have a macbook a1706 (820-00923-A) that does not turn on, the 20v ubc triggers but no power consumption, no short and no liquid damage, PPBUS_G3H: 0V15 (16mohms no short), U7000 is well powered by the 20V, I looked at everything around the ISL9239 chip the resistors are good, so I replaced the chip twice but the result is the same, my skills stop there can you help me please?
                                02-17-2025, 12:32 PM
